Super Charger vs. Turbo
Old Apr 24, 2003
AvrilLavigne45's Avatar
AvrilLavigne45 is an unknown quantity at this point
Is either a supercharger and a turbo charger connected to your a/c. If so will it affect the maximun coolness or heat coming out of my vents?
Old Apr 24, 2003
RoadRunner's Avatar
i dont think either are hooked up to your a/c
Old Apr 24, 2003
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
no.
Old Apr 24, 2003
mattskav's Avatar
mattskav is an unknown quantity at this point
Turbos and superchargers alone wont touch the ac (unless the supercharger comes witha a different diameter crank pulley.
If you are talking about products that use the air conditioning to cool the intercooler?
Yes they will affect the amount of cooling, conservation of energy.
Old Apr 24, 2003
bublik's Avatar
Truehonda.com
bublik is an unknown quantity at this point
You say you drive a car and are an enthusiast...... righhhhtttt! JK bro, yea, they have nothing to do with eachother. You are just mistaken into thinking the supercharger gets its power from the belt that powers the AC. I guess you can think that if the supercharger is going off a pulley that is connected to the belt, that the AC has less power to use from the belt which is engine power?!? Whatever, go forced induction and have fun.
Clutch coming = Nitrous Install Yeaaaa
Old Apr 24, 2003
bublik's Avatar
Truehonda.com
Old Apr 25, 2003
Da2K1's Avatar
Da2K1 is an unknown quantity at this point
Neither will affect your A/C. Getting a super charger to fit, will be tricky- there isn't a lot of room in our engine bays, to fit one. IMO it will be better than a turbo, though.
Old Apr 25, 2003
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
A good place to start reading....
http://www.superchargersonline.com/
Old Apr 28, 2003
great advice thanks guys
Old May 1, 2003
diganutz's Avatar
diganutz is an unknown quantity at this point
The only other way you could effect it is if you change the size of your engine pulleys. This can either slow down or speed up you A/C compresser. If you run underdrive pulleys (ie slow down the belt) you slow down your compressor your A/C will suck.
Since most/all superchargers for Civics are belt driven (and shared with the a/c) if you change your engine pulley you will effect you A/C/electrical/powersteering
So bublik they do have something to do with one another. However if you don't change you pulleys, there will be no effect (unless you blow your belt from to much load)
Also You can use a your aircondition system to create a super dense (Ie cold) charge for quick acceleration. Read up on the New Ford F-150 SVT truck.
HondaGuy7
Feb 22, 2016 01:00 PM
Cam Diaz
Sep 29, 2015 07:17 PM
General DIY
Sep 25, 2015 08:02 PM
h4ldol
Sep 17, 2015 01:25 PM
MamaBear2015
Sep 7, 2015 06:00 PM
