RSX Swap Club
Anyone interested in starting a Swap Club in the South East area? I would like to get in contact with anyone that has an enigine swap. I call it RSX swap Club because I will be getting one next month and would like to talk with other RSX Swappies.
$8000 to $10000!!!!!
Where did you see those prices???
Brand new K20A1 (thats JDM Type-R) w/ 6-speed, ECU, and shift linkage is $5600, i'll try to find the website that was selling them.
Hasport makes the mounts which don't cost much.
The only way i can see the cost getting up towards $8000 is if you pay some shop to do it and they really overcharge you.
http://www.jdmhondaparts.com/engines.htm
at the bottom, $6500, im still looking for the site that had them for $5600
u can get it at jdmhondaparts.com. u r going to need the rsx subframe and probably the drive axles. just the motor mounts from hasports, the engine, tranny, and ecu won't be enough.
well i think i found the site you MIGHT have gotten those high prices from
http://www.andrewsimportperformance.com/engines.htm
$8100!!! Thats crazy and its only for a K20A2
Then you add the labor costs for the swap. I heard labor costs as high as $2000. I believe Chrissy got that $2000 labor quote, if i'm not mistaken.
Good luck on the swap though. I think that's a pretty good idea about starting that club. I wish I was part of it.
That is a place where you get everything to a good price and i was quoted $500 for labor.HONDA MOTORS
- K20A2 or K20A3 (from Civic Si) Engine With:
- AC compressor
- alternator
- P/S pump or idler pulley (from Civic Si)
- wiring harness
- exhaust manifold and catalytic converter
- ECU
- Transmission and starter
- intermediate shaft
- Axles from either 02 Civic Si or 94 up Integra GSR (we used 02 RSX with RSX knuckles and hubs)
- RSX or 02 Civic Si subframe
- Hasport ESK1 bolt in mount kit (as of this time the kit will not work with the K24)
- Hasport ESKWH conversion wiring harness
- RSX shifter assembly and cables
- 02 Civic Si radiator and fans (although the RSX will fit with some trimming around the radiator cap opening in the grill)
- 02 Civic Si upper and lower radiator hoses (RSX are longer and may kink)
- RSX throttle cable
- RSX fuel line, brake booster line and purge line
- RSX AC line from compressor to condensor
- RSX clutch lines from the master cylinder to the slave cylinder
- Custom AC line from compressor to evaporator (Hasport should have one available by April)
- 90 Accord negative battery cable
- If you want powersteering:
- RSX high pressure powersteering hose and return line
- 92 Civic P/S resevoir w/ bracket and a section of hydraulic hose to go from the pump to the resevoir
do your research
ThatGuy913
Sep 28, 2015 05:35 PM
PunX
Sep 23, 2015 10:45 PM
Touge
Sep 22, 2015 11:55 PM
Touge
Ottawa
Sep 22, 2015 11:52 PM
Touge
