engine bogs down and stops when idling
Old Apr 1, 2003
Chrissy's Avatar
Chrissy is an unknown quantity at this point
hi you guys i got my "used" civic yesterday at a dealership and sometimes when i am at a stop light the rpms would be at like 400 or lower, like 300 and then the engine would die. the last guy who owned the civic has these mods, i/h/e. plz help. the engine has 23000 miles and my guess is that i may have been driven hardd, someone plz tell me whats wrong
Old Apr 1, 2003
flotsamm's Avatar
It could be alot of things. Probably best to take it in for a diagnostic check or see if they can pull any stored codes from the computer. If they find any codes then you might be able to track down the problem and fix it yourself. Could be something simple as a clogged air filter, fouled plugs, dirty injectors, etc to something far more serious.
Old Apr 1, 2003
Mbow's Avatar
Sounds like you got one of the '01 duds. Lots of members have had issues with the idle and the car even stalling when in motion.
I think it was eventually traced to a bad batch of ECUs but not sure.
I'd take that car back TODAY. If they can't fix it, give it back!
Old Apr 2, 2003
Pinoy3LeR's Avatar
Pinoy3LeR is an unknown quantity at this point
if the idling of your car is your problem then you should go back to your dealer to have the ECu reseted since we have a distributorless engine,they have this special tool that they bolt in to your ecu and reads whatever the problem is,or you could adjust the air mixture in your engine,there is a small bolt there near your throttle body heater,w/c you need a small allen wrench to adjust...hope this HELPS
Old Apr 2, 2003
Chrissy's Avatar
ah ha! i did the diy - tightening the throttle cable. it werked! YAY!!~! now, i idle at 1400 rpm cold, 1000 warm.
Old Apr 2, 2003
solar's Avatar
solar is an unknown quantity at this point
1000 rpm is to high at warm idle, you should be around 750 to 800 rpm.
Old Apr 2, 2003
flotsamm's Avatar
Yeah thats to high. All your doing is wasting gas and if you have an automatic tranny your putting more stress on it.
Old Apr 2, 2003
Mbow's Avatar
I suppose the previous owner could have tried the diy and messed up the idle.
I think it's more likely that you have a problem that a lot of others have had.
Your idle is to high. Let the dealer fix it. If it has under 36k it's a warranty repair anyway.
Old Apr 2, 2003
Chrissy's Avatar
betcha the dealer will charge me for it so at least i fixed it now to idle at 800 cold, 600-700 warm
Old Apr 2, 2003
Mbow's Avatar
I don't think the dealer would charge you for it. There is absolutely no reason for them not to cover it under warranty. Well, unless they notice the cable has been adjusted. The dropping idle is a common problem. Not common in that a whole lot of civics are affected, just something some of the unlucky people have experienced.
If you are affected by the idle problem, messing with the cable isn't going to fix it. You will find out soon enough. Hopefully, you took care of it.
Old Apr 2, 2003
Chrissy's Avatar
ill see if it does it tomorro if it still does, i'll see about the dealer
Old Apr 3, 2003
Bartkat's Avatar
There's two cables. Is one the idle adjustment, and the other one the throttle cable?
Old Apr 4, 2003
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
It is the intake sensor. Time to get a new one.
Old Apr 4, 2003
Chrissy's Avatar
you mean the mass air flow sensor?
Old Apr 4, 2003
NorrinRadd's Avatar
NorrinRadd is an unknown quantity at this point
If you continue to have problems though you may want to check if the previous owner did the DIY for bypassing the throttle body heater. If so, it may have screwed up your mass air sensor and throttle body temp sensors (i.e., they can't sense anything or very little). This is because if the bypass tubes are not installed perfectly (i.e., no bends, etc.) there will restrictions and these errors will show up in the odb diagnostics. Even though, this DIY is only a bypass it needs to be done perfectly so air/fluids still flow with no restrictions whatsoever. Easiest thing to do if this is the case, is to just undo the DIY and reset your ECU. This will bring back proper flow and reset the 2 error codes in your ECU this DIY causes if done wrong. Hope this helps...
Old Apr 4, 2003
VTECnique's Avatar
VTECnique is an unknown quantity at this point
not the intake sensor, its the MAP sensor. i had the same problem
Old Apr 4, 2003
Derek-CEO's Avatar
Derek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz Erthang
it was a recall. have them check your VIN and see if it was done. more than likely it hasn't. Mine had the saem prob when I got it.
D
mikemc422
Aug 9, 2018 05:41 PM
beneditti
Jan 15, 2016 12:31 PM
crowtoo
May 11, 2015 06:50 PM
McD
Apr 29, 2015 03:50 PM
Coopex
Jan 20, 2002 12:22 AM
