What is a tranny bracket for an intake
Are you talking about that metal bracket coming off the intake in the pic? When you remove the existing intake(all that black plastic shiznt!!!) you will put on the new intake and see that it bolts right into a spot on the engine.
Its easy.
Its easy.
Yep, you don't need a trans bracket for SRI. The bracket you have is just a support that bolts up to one of the threaded holes left when you remove the stock intake resonator. Easy to see where it goes when you get the old intake off.
yep, that metal thingy sticking out of the pipe basically gets mounted on the stock mounting point where the stock airbox used to be mounted... you can use the stock screws to screw in that intake
you might want to put a thick rubber washer in between to cut down on rattling
you might want to put a thick rubber washer in between to cut down on rattling Thread
jammer48
Oct 4, 2018 10:04 PM
velozp
Dec 13, 2015 11:28 AM
mistahlorax13
21
Nov 18, 2015 12:47 PM
thaler4cuse
Sep 7, 2015 08:25 PM
dantheman42
Sep 4, 2015 01:10 PM
