Wheel Offset Explanation????
Old Mar 6, 2003
money9's Avatar
money9 is an unknown quantity at this point
Can someone please help me. I am looking for a set of rims, I am looking to buy a set of 18's (undetermined style) and I am unclear what the offsets mean. Can someone please give me a little more background information on how the offset works or what is refers to PLEASE?
Old Mar 6, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
From my Rim tutorial at the top of the page....
Quote
[hr]The offset on the rims I want is different than stock, will it work?
It depends. If there is not enough offset, you'll have trouble with the brakes fitting in. There are also some rims with very wide lips that are intended for RWD cars that may not work. The offset is the distance (in mm) from the centerline of the rim to the mounting face on the rim. Positive offsets will bring the wheel further into the fenderwell, Negative will push them out. Anything in the 39-44 range should work no problem, but it also depends on how wide the new rim is. Remember that the offset of the new rim is relative to that rim, NOT the stock one. Assuming positive offsets (you shouldn't use negatives, the car will be bowlegged): If the new wheel has less offset (lower number), add the offset difference to 1/2 the difference in width between the 2 rims. If the new wheel has more offset, subtract the offset difference. Less than stock will push the rim further out, more than stock will pull it in.
[hr]
Old Mar 6, 2003
666's Avatar
666
666 is an unknown quantity at this point
Well said.
nirvanaguy
25
Oct 26, 2017 07:26 PM
twd000
Oct 4, 2015 12:52 PM
siliconvalley
Sep 15, 2015 09:48 PM
junkyardguy
20
Sep 6, 2015 10:07 PM
Strycker
Aug 18, 2015 02:25 PM
