wiring cap
Old Feb 19, 2003
macrossranma's Avatar
macrossranma is an unknown quantity at this point
wiring cap
i have a lightling strike 1.0f cap, got it used, no other hardware accessory, just want to make sure i do everything right before i shock myself or damage my system, i have only 1 amp, so i just connect the battery wire to the positive of cap and than negative of cap to the car chassis?do i need extra hardware to connect the wire to amp or i can use the same point that connect battery to cap to wire up the amp?
it would help alot if anybody have a pic of a single cap and a single amp wired up
thanx[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Feb 19, 2003
doubledeuce2k2's Avatar
battery connects to top of cap, as does a wire that goes to your amp, on that plus terminal. and yes you ground the - end of the cap to the chassis. be sure to ground it first, btw. also put a resistor of some sort in between the battery wire and the + of the cap when you first charge it. a DC light works good, since the light will get dim as the cap charges. when the light gets fairly dim, or after about a minute, you can connect the battery wire directly to the cap. it should only take a few seconds to charge the cap, but a minute is a saftey measure.
Old Feb 19, 2003
okie, thanx, but how about hte remote control wire from the headunit? do i still connect the remote control wire to the amp or i have to connect to the cap?
Old Feb 20, 2003
DizWikedCivic's Avatar
Quote
[hr]Originally posted by: macrossranma
okie, thanx, but how about hte remote control wire from the headunit? do i still connect the remote control wire to the amp or i have to connect to the cap?[hr]
yes the remote still goes to the amp
Old Feb 20, 2003
no remote to cap, technically a cap is always on, but there is very little internal resistance so hardly any power is used by it, don't worry about it draining your battery.
Old Feb 20, 2003
fonto's Avatar
The LA Clipper
Quote
[hr]Originally posted by: DoubleDeuce2k2
no remote to cap, technically a cap is always on, but there is very little internal resistance so hardly any power is used by it, don't worry about it draining your battery.[hr]
Then why are there connectors for the remote turn on lead on caps? [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Feb 20, 2003
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
at least for mine, it has a rem terminal to know when to turn on the indicator lights and the voltage readout
Old Feb 21, 2003
i have the lightning strike 1 farad digital cap, how can i wire the remote turn on?what does the remote turn on wire do?and do i connect this wire from cap to headunit OR from cap to amp?anybody have any installation manual?thanx, i installed the cap but no digital display guess its because im missing the remote wire[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
and is it ok to ground the cap AND amp at same ground point?
Old Feb 21, 2003
Quote
[hr] have the lightning strike 1 farad digital cap, how can i wire the remote turn on?what does the remote turn on wire do?and do i connect this wire from cap to headunit OR from cap to amp?anybody have any installation manual?thanx, i installed the cap but no digital display guess its because im missing the remote wire [hr]
your cap should have a little screw that says remote or rem. you can terminate the remote wire with a spade connector and slip it under that screw. the remote turn on wire sends +12 volts when the car is switched on. all devices in your system that have a REM connection need to be connected to either the headunit or the cigarette lighter. i choose the lighter because its easy to fry your headunit when you connect too many devices to the REM wire of your headunit.
Old Feb 21, 2003
can i connect the rem terminal on cap to the powercontrol wire on the amp?and is it OK to use same ground point for the cap and the amp?[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Feb 21, 2003
fonto's Avatar
The LA Clipper
Yes, use the same ground point for sure. For the remote wire, I just split mine right before the amp and butt connected/E-taped two additional wires on too it(one to go to the cap, and one to go to the second amp...so three wires total). [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Feb 22, 2003
umm, i use the power control slot on the amp and wire it to the rem of cap, but the digital doesnt work, pls help, thanx[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Feb 22, 2003
check that all connections are tight and secure, espeically ground. and then bust out your DMM and make sure the wire connected to REM is showing +12 volts when the car is on
Old Feb 22, 2003
dmm?i tired to connet the power control wire from the head unit directly ot the rem on cap but no display
Old Feb 22, 2003
dmm=digital mutlimeter it measures amps, volts, and ohms, its a great tool to have.
Old Feb 22, 2003
in theory if i connect the power control wire from head unit to the rem on cap, the display should work?
Old Feb 22, 2003
i mean if i dont connect the power control wire to amp, but intead i wire it to cap directly(amp no power), the display on the cap should work?
Old Feb 22, 2003
yeah it should
Old Feb 22, 2003
umm...display borken than, thanx for your help!![IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Hqly2001
22
Jul 12, 2015 06:44 PM
JUNITO
Jul 9, 2015 08:36 PM
aultman1990
Jul 9, 2015 08:27 PM
Bounddyy
Jul 8, 2015 11:22 AM
robbie374
Jul 7, 2015 02:56 AM
