wiring cap
wiring cap
i have a lightling strike 1.0f cap, got it used, no other hardware accessory, just want to make sure i do everything right before i shock myself or damage my system, i have only 1 amp, so i just connect the battery wire to the positive of cap and than negative of cap to the car chassis?do i need extra hardware to connect the wire to amp or i can use the same point that connect battery to cap to wire up the amp?
it would help alot if anybody have a pic of a single cap and a single amp wired up
thanx[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
battery connects to top of cap, as does a wire that goes to your amp, on that plus terminal. and yes you ground the - end of the cap to the chassis. be sure to ground it first, btw. also put a resistor of some sort in between the battery wire and the + of the cap when you first charge it. a DC light works good, since the light will get dim as the cap charges. when the light gets fairly dim, or after about a minute, you can connect the battery wire directly to the cap. it should only take a few seconds to charge the cap, but a minute is a saftey measure.
okie, thanx, but how about hte remote control wire from the headunit? do i still connect the remote control wire to the amp or i have to connect to the cap?
Quote
[hr]Originally posted by: macrossranma
okie, thanx, but how about hte remote control wire from the headunit? do i still connect the remote control wire to the amp or i have to connect to the cap?[hr]
no remote to cap, technically a cap is always on, but there is very little internal resistance so hardly any power is used by it, don't worry about it draining your battery.
The LA Clipper
Quote
[hr]Originally posted by: DoubleDeuce2k2
no remote to cap, technically a cap is always on, but there is very little internal resistance so hardly any power is used by it, don't worry about it draining your battery.[hr]
i have the lightning strike 1 farad digital cap, how can i wire the remote turn on?what does the remote turn on wire do?and do i connect this wire from cap to headunit OR from cap to amp?anybody have any installation manual?thanx, i installed the cap but no digital display guess its because im missing the remote wire[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
and is it ok to ground the cap AND amp at same ground point?
Quote
[hr] have the lightning strike 1 farad digital cap, how can i wire the remote turn on?what does the remote turn on wire do?and do i connect this wire from cap to headunit OR from cap to amp?anybody have any installation manual?thanx, i installed the cap but no digital display guess its because im missing the remote wire [hr]
can i connect the rem terminal on cap to the powercontrol wire on the amp?and is it OK to use same ground point for the cap and the amp?[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
The LA Clipper
Yes, use the same ground point for sure. For the remote wire, I just split mine right before the amp and butt connected/E-taped two additional wires on too it(one to go to the cap, and one to go to the second amp...so three wires total). [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
umm, i use the power control slot on the amp and wire it to the rem of cap, but the digital doesnt work, pls help, thanx[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
check that all connections are tight and secure, espeically ground. and then bust out your DMM and make sure the wire connected to REM is showing +12 volts when the car is on
JUNITO
Jul 9, 2015 08:36 PM
robbie374
Jul 7, 2015 02:56 AM
