AMP STARTED SMOKING FOR NO REASON!
Old Feb 17, 2003
Aznnp77's Avatar
All Show No Go Sedan
Aznnp77 will become famous soon enoughAznnp77 will become famous soon enough
Okay, I've had the same setup for about 5 months, no alterations at all, and it always worked fine until valentines day. I was listening to my music pretty loud and then suddenly the bass sounded like it was having trouble hitting. It would go a few notes, then cut off, then go more, and so on. So I turned it off. Later I kept it pretty low and it kept doing the same thing, so I just kept the volume very low, and eventually the bass just went away all together. While I'm on the highway a friend notices a weird smell, and I recognized it too. It was something in my system burning. I pulled over and found that my amp had smoke coming from it. I disconnected the ground, and it continued to smoke, so I disconnected another wire, dunno which one it is. It still smoked. So I disconnected the power wire and it finally stopped. I just got around to checking it out tonight. The fuse it ok, the wiring seems to be connected correctly, and I still haven't made any modifications for like the last 6 months. What could my problem be? Im sending the amp back and getting another one, but I would like to see what the problem is before I fry another perfectly good amp.
Old Feb 17, 2003
Aznnp77's Avatar
I just disconnected all my glow lights, etc. Then rehooked up the amp, it only goes into protect. Even with the car off, the light still comes on, odd...
Old Feb 18, 2003
doubledeuce2k2's Avatar
you have some ***** to hook up an amp after it was smokin' up your trunk
Old Feb 18, 2003
Subrage's Avatar
Subrage is an unknown quantity at this point
possible that it got to hot and some of the sauder melted and short circuited it.
bad ground
what kind of amp was it
Old Feb 19, 2003
Aznnp77's Avatar
Lanzar Vibe 1200D. 1 ohm stable, I wired it to 2.6 ohms. Worked fine for the last like 6 months.
Old Feb 19, 2003
iluvbritney's Avatar
iluvbritney is an unknown quantity at this point
maybe u banged it too loud? not set for that much of bangin
thana
Jun 15, 2020 07:05 PM
crowtoo
May 11, 2015 06:50 PM
smmahan
Apr 15, 2015 08:17 PM
black2k1vtec
Dec 6, 2001 09:49 PM
