Need Help with headlights
00 Hatchback Owner
Hey guys, as you all know, or might not know, I have a 2000 dx hatchback, Im trying to figuare a way to raise the headlight beam but i cant find the screw/botton/**** to do it, i took a picture of what i think you turn to do it but im not sure hmmmmmmmso if u could help, thanksif you want to see the car, and i got a new headunit BTW!
do you just want to adjust the bulb? if so, i don't know if it can be done. make sure the bulb is seated properly and tightened into the headlight assembly. That should make sure it is straight.
00 Hatchback Owner
the blub is in there correctly , but the beam aims like 30 feet up and it doesnt show anything above the line, so basically its aimed at the ground so how do i fix it i posted pics of what i think you unscrew and move to fix it but im not sure
i know what your talking about. There is like a big bolt or screw that you have to adjust to lower or raise the headlight. I just dont know where it is on the 00 hatchback. Sorry man. Good luck.
meicalnissyen
Sep 25, 2015 12:12 AM
rnaodm
Sep 21, 2015 12:42 PM
shaejb15
Sep 12, 2015 01:02 AM
Bricoleur
Sep 9, 2015 12:23 PM
MamaBear2015
Sep 4, 2015 09:04 PM
