Amps, wires, and caps oh my! Help me!
Old Feb 12, 2003
DIMO's Avatar
DIMO is an unknown quantity at this point
okay so far I have Focal Utopia's 165W components with 2 Image Dynamics 12in IDQ12V.2 D2. What kind of amp should I get for the subs? I have a tubedriver for the components already. Also what else would I need to complete the install, like wires, fuses, caps. Can you mention some quality companies who makes those products. I haven't picked up a head unit yet, I want either a Alpine or Eclipse somewhere around 400-500 which model would you guys recommend.
Old Feb 12, 2003
noahnoah's Avatar
noahnoah is an unknown quantity at this point
Well for starters you're gonna need a/some:
power wire, rca cables, speaker wire, and possibly some female/male disconnects. For fuses/wires etc.... you should be able to pick them up just about any hardware store or you local car audio store. Phoenix gold makes alot of those accessories that you will need and I have found them to work fairly well. As for the amp, I think the JBL 600.1 would be a good amp for those speakers. They hold something like 350watts rms? The 600 should do them well. Or you could go with something a little bigger and gain a little headroom.
Old Feb 12, 2003
Subrage's Avatar
Subrage is an unknown quantity at this point
nice stuff [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
well since you have good equiptment, you will probably wanna stay with more good equiptment
look into some pheniox Gold ti amps or arc audio
Old Feb 12, 2003
LudlamTheory's Avatar
i boogie for the raindrops
Quote
[hr]Originally posted by: noahnoah
power wire, rca cables, speaker wire, and possibly some female/male disconnects. For fuses/wires etc.... you should be able to pick them up just about any hardware store or you local car audio store. Phoenix gold makes alot of those accessories that you will need and I have found them to work fairly well. As for the amp, I think the JBL 600.1 would be a good amp for those speakers. They hold something like 350watts rms? The 600 should do them well. Or you could go with something a little bigger and gain a little headroom.[hr]
noooooooooooo..... you dont want to use a jbl amp with those subs, especially if he's using utopia's...
as for cable, cable is cable... just as long as rca's are shielded and its installed correctly youll be fine...
as for an amp, go wiht that subrage said... phoenix gold ti's or arc audio would be great. also ppi, theres other brands that are up there in quality
Old Feb 13, 2003
Mystic3030's Avatar
Yup, i'm an A$$hole.
You could also check out Diamond Audio, Braxx, or the mid grade Zapco line.....if those are too expensive, try JL Audio.
Old Feb 13, 2003
IDQcivic's Avatar
IDQcivic should not be trusted
Congrats on the subs! I thought I was the only one here with them, this my name hehe... well you will be very happy with them, I had mine hooked up to a US amps usa 150 and they pounded hard, hit well into the 140's in a ported box. I recently upgraded my amp to an audiobah amp and they pounded even harder, until something malfunctioned (see my other post!) well good luck with the install, IDQ's rule!
Old Feb 13, 2003
noahnoah's Avatar
why nooooooo JBL amp?
jru27
Jun 19, 2015 03:51 PM
dpru
May 26, 2015 07:01 PM
jackoncruzpr
May 24, 2015 12:24 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
OPGForce
Feb 7, 2002 09:43 AM
