one Kappa perfect 12" 4ohm and kenwood kac-x520 500wrms x 1 bridge
Old Feb 2, 2003
macrossranma's Avatar
macrossranma is an unknown quantity at this point
one Kappa perfect 12" 4ohm single voice coil and kenwood kac-x520 500wrms x 1 bridge, my kappa sub is 4ohm, can i push full 500wrms bridged to my sub??i dont understand the definition of bridge
Old Feb 2, 2003
LudlamTheory's Avatar
i boogie for the raindrops
is that 500x1 bridged at 4 ohm?
Old Feb 2, 2003
fonto's Avatar
The LA Clipper
Nice amp dude! Yes, you should be able to run the 4 ohm perfect of off that amp in bridge mode (but no less) Bridge mode is hard to explain in words without a picture...but if I know kenwood products like I think I do, there should be a chart/picture on how to do it. If you can't figure it out PM me and i will find a link that shows a diagram.
That amp can most likely put out more then 600 watts. Will you be running that sub ported? Perfects can handle more watts ported then sealed if the infrasonic filter is set right.
Anywayz, that should be a tight set-up!
I just went to Infinity's website and they have a new alternate version of the Perfect called 12 VQ...is that the one you got?
Old Feb 2, 2003
thanx do u know if our stock alternator can handle 13.3 or 14+ volts?, im running the kappa perfect 12 with sealed box, just the old 12.1, not the new version
Old Feb 3, 2003
fonto's Avatar
The LA Clipper
Yeah, you should be fine...I used to run 2 10" perfects with 600 watts each from a JBL 1200.1. Your alternator should be fine [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
SammySC
121
Apr 7, 2017 07:43 PM
Munzy
21
Oct 7, 2015 07:48 AM
Wariogamer
Sep 29, 2015 09:49 AM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
