another rca question
Old Feb 2, 2003
BaNgCiViC2k1's Avatar
BaNgCiViC2k1 is an unknown quantity at this point
i got a stock head unit and the guy from best buy told me that the best way to go about connecting my amp is to get an rca adapter for it. What i am wondering is where do i plug in the 2 plugs (red, white), the cable is silver and is long enough to go from the trunk to the head unit but i am guessing i cant connect it there because i have a stock unit? Also i have the other 4 wires tha come out of the rca connected to my amp.
Old Feb 2, 2003
LudlamTheory's Avatar
i boogie for the raindrops
okay... so lets start this simple...
first, whats the amp for, a sub?
Old Feb 2, 2003
yea one sub
Old Feb 2, 2003
Ed's Avatar
Ed
I'm not sure what you are saying, but I believe what the Best Buy dude said was that you need a line level convertor, so you can tap into your speaker channels from your stock HU and then connect RCA cables to the line level convertor. Then, you can connect the RCA cables to your amplifier. If you Amplifier has Speaker level inputs, you can tap the rear channels directly to the amplifier
Ed
Old Feb 2, 2003
So i can tap the 4 or 5 wires from the rca to the speakers and then connect it to the amp,can i do the tap from the trunk or must i pull the HU out and tap from there.
Another thing, in my amp kit that i bought, it has one red cable for power that i ran from the battery to the trunk and it has a short cable that is for ground. Thats all the cables it came with, so theres nothing to connect power to teh sub from the amp, can i just cut a piece off and use that ..
Old Feb 2, 2003
you can tap it from the rear speakers in the trunk...
Old Feb 2, 2003
doubledeuce2k2's Avatar
Quote
[hr]so theres nothing to connect power to teh sub from the amp, can i just cut a piece off and use that [hr]
can yes. should no. buy some speaker wire, 14 or 12 gauge is plenty, and you only will need a few feet. you'll probably need a long piece to use as a remote turn on lead, or a wire that is hot when the car is on (not off) to turn the amp on. (use speaker wire here too)
Old Feb 2, 2003
dont understand, so how does it kno to turn on and off
Old Feb 2, 2003
Quote
[hr]Originally posted by: BaNgCiViC2k1
dont understand, so how does it kno to turn on and off[hr]
it looks to me like you should get it professionally installed or installed by a friend.... at least get someone that knows what theyre doing to help you, or you might screw something up royally...
Old Feb 3, 2003
jefff's Avatar
jefff is an unknown quantity at this point
I'll second ludlam.
if you don't know what it does it's best to eithe rtake the time to learn it or get a pro. Don't learn on your new car!
robjcivic
Mar 12, 2017 12:10 PM
JMKendrick
Sep 16, 2015 06:17 PM
redcloud
Sep 7, 2015 01:45 PM
junkyardguy
Sep 2, 2015 06:07 PM
redcloud
Aug 26, 2015 11:27 AM
