DIY on installing Alteeza Tail Lights?
Old Jan 31, 2003
blackcivic28's Avatar
blackcivic28 is an unknown quantity at this point
Ok, I know about 50 people will say that I should use the search engine but the search engine sucks ***. [IMG]i/expressions/face-icon-small-puke.gif[/IMG]
But, if anyone has any links to an installation guide on how to install Alteeza tail lights, I would appreciate it because I am installing them next week. I have a 2002 LX sedan just to clarify.
Thanx in advance
Old Jan 31, 2003
dragoon's Avatar
1. unplug old tail lamps
2. take out old tail lamps, something like 4 bolts, if they dont come out, check behind carpet for bolts you missed
3. put in altezzas
4. plug in altezzas
5. +500hp
and next time PLEASE SEARCH. there is absolutely nothing wrong with the search engine, it isn't even hard to use unless you're a monkey.
Old Jan 31, 2003
XxSoVeReiGNxX's Avatar
Quote
[hr]Originally posted by: dragoon
3. put in altezzas
4. plug in altezzas
5. +500hp
and next time PLEASE SEARCH. there is absolutely nothing wrong with the search engine, it isn't even hard to use unless you're a monkey.[hr]
damn yo! 500+hp really? **** man! I'ma bout to go take me on a 'stang!
Anybody who had hands-on toys (lego, erector, k'nex) will find installing the tezzas easy as hell. I put them on in 30 minutes, and that was years before I even knew this site was around.
Old Jan 31, 2003
The sedan tails are a lot harder to do. There are two screws for each assembly that are behind the bumper. You can try to reach underneath, but most likely the bumper will have to come off. I took mine out to get the screws off and it wasn't too bad.[IMG]i/expressions/face-icon-small-cool.gif[/IMG]
Old Jan 31, 2003
LC's Avatar
LC
LC is an unknown quantity at this point
It takes about 3 seconds Take out the 3 or 4 bolts... Take out headlights....Put new headlights in.... Put back bolts.... Its that simple.... I know a kid that payed someone $45 to install his altezza's:
Old Feb 1, 2003
hankscorpio's Avatar
hankscorpio is an unknown quantity at this point
30 mins? even that is way too long. But yeah for the sedan it is more complicated. Like he said you probably have to end up taking the bumper off.
Old Feb 1, 2003
Quote
3. put in altezzas
4. plug in altezzas
5. +500hp
Thanks for the help and thanks for being an ***, try the search at the top in the tech stuff forum, tell me what you come up with! [IMG]i/expressions/face-icon-small-mad.gif[/IMG]
I used the keywords alteeza install, DIY altezza, tail light install, parking light install, and DIY parking lights and I didnt get any f#$king results so why dont be an *** when you know you are right. [IMG]i/expressions/moon.gif[/IMG]
Old Feb 1, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
Don't just search the Tech forum. Click the big shiny button that says SEARCH on the top right corner of the screen and search the whole site. I know for sure there is a DIY for both coupe and sedan tails on here because I have found and read them both. They were probably in the Parts and Products forum.
Sedan Tails
So why not try searching more than one forum before you go ranting about searching and finding nothing.
Old Feb 1, 2003
Vinnie's Avatar
Vinnie should not be trustedVinnie should not be trustedVinnie should not be trustedVinnie should not be trusted
Aite man. Take out the bolts 6 bolts (3 on each side) that u find in your trunk. Crawl under the car and look up, youll see a screw on both sides. Take em out, but dont bother with the screws that are horizontal. Just use alot of muscle and yank your light out. I think i only broke part of one light when i did it.
Old Feb 2, 2003
CivicHX01's Avatar
1. put them back in the box
2. return them
3. use the money on something else...
there's your DIY
Old Feb 3, 2003
bond007's Avatar
bond007 is an unknown quantity at this point
ok i just got done installin mine. hear is what u do
1. take out the 3 bolts on each side
2. crawl under the car and look up u will see a philips screw on each side take it out
3. take a flat head screw driver and a hamer break of the tabs on the bottom of the oem lights
4. remove oem and install new
Poopies
Apr 20, 2017 11:36 PM
shaejb15
Apr 12, 2015 11:38 AM
1028CiViC
Bolt-on Engine Performance
Nov 18, 2001 05:02 PM
ROBREALZCIVIC
Nov 16, 2001 06:53 PM
