2 amps to choose from
Old Jan 29, 2003
Staticfree's Avatar
Staticfree is an unknown quantity at this point
there are 2 amps that I'm looking at that fit my price range exactly.
Kenwood KAC-629s 2/1-Channel Car Amplifier
MTX T4122 2/1 Channel Car Amplifier
I'm gonna be running only the front speakers off the amp, and am getting Infinity 605CS 6" Speakers.
I really don't understand the different in specs, so any advice is appreciated.
Currently have the Kenwood eXcelon X859, and will be running my back speakers off this.
Old Jan 29, 2003
666's Avatar
666
666 is an unknown quantity at this point
[IMG]i/expressions/face-icon-small-smile.gif[/IMG]Kenwood.[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Jan 29, 2003
fonto's Avatar
The LA Clipper
I have owned both Kenwood and MTX 4-channel amps (I currently have the MTX 4244 in my car powering my front speakers), and i think that there are Pro and Cons with both.
Kenwoods tend to have more features and mine lasted forever (8+ years, and my gf uses it now, but one of the rear RCAs is out). I also used another one last year, but I ended up returning it because it was not enough power for my subs. I think that Kenwoods are pretty accurate in terms of their power ratings
MTXs are usually WAY underated in terms of power, but they usually do not have as many features as Kenwood.
Both companies make good low cost amps, and IMO you can not go wrong with either I would go with the features that you want, and maybe with the one that you think looks better [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Jan 29, 2003
Staticfree's Avatar
Features? what do you mean by features? i tot all amps do is power the speakers
anyway, here is some info about each. I just listed those that are different in both.
i don't understand what they mean...
Kenwood
14.4V Dynamic Power At 2 Ohms 350 Watts
2 OHM Output Power - Full Range 2 x 75
4 OHM Output Power - Full Range 2 x 60
Bridged Power At 4 OHMS - Full Range 1 x 150
Total Max Power 350 Watts
MTX
14.4V Dynamic Power At 2 Ohms 200W
2 OHM Output Power - Full Range 80W X 2
4 OHM Output Power - Full Range 50W X 2
Bridged Power At 4 OHMS - Full Range 120W
Total Max Power 120W
Old Jan 29, 2003
fonto's Avatar
The LA Clipper
What are the model numbers? And how much for each?
edit: duh you already said what model numbers in the first post!
Old Jan 29, 2003
madmax's Avatar
madmax is an unknown quantity at this point
I am currently running two of those MTX 's in my car, one for the front speakers and one for the sub.
I LOVE THOSE THINGS!!!!!!
They are way underestimated! and they sound GOOD!
Old Jan 30, 2003
LudlamTheory's Avatar
i boogie for the raindrops
how much do those cost?
Old Jan 30, 2003
ChemicalBoom's Avatar
ChemicalBoom is an unknown quantity at this point
I like MTX amps personally and they look a lot better with the chrome and everything. just my personal experience
Old Jan 30, 2003
DizWikedCivic's Avatar
im going with fonto with on this too, imo mtx is way overated, but you cant go wrong with both companies
Old Jan 30, 2003
Staticfree's Avatar
Cool! Thanks for all the info! From what I've read, both are just as good. So now, all I have to decided on is looks or size. The kenwood is C$159, and the MTX is C$169.
I don't want to mount the amp on my back seats, so I'm gonna put it where the spare tire is, inside the spare rim. I'm gonna DIY a board that the amp can sit on that fits into the spare rim.
Only question is whether the amp will overheat. in that confirm space. any idea?
Old Jan 30, 2003
WhiteRabbit's Avatar
if teh amp is prone to overheat, it wont matter whether you wrap it in bubble wrap, or have it bolted to the side of the box. itll heat up.
only active cooling will help overheat.
dont worry about heat till its a problem. like they say, if it aint broke dont fix it, yes?
Old Jan 30, 2003
Staticfree's Avatar
i've checked and the mtx will fit perfectly under the mat in the trunk! the space in front of the spare. i'm gonna build a board and fix it up in there, out of sight. i sometimes need to put my back seats down, so mounting on back seat is not good. i'll post some DIY measurements when i'm done, if anyone is interested.
Old Feb 1, 2003
noahnoah's Avatar
noahnoah is an unknown quantity at this point
Go with the Kenwood buddy!
h4ldol
Apr 24, 2017 08:16 PM
UltraHDGames
Jun 8, 2016 05:16 PM
General DIY
Sep 25, 2015 08:02 PM
Mc7602
Sep 17, 2015 02:01 PM
redcloud
Sep 7, 2015 01:45 PM
