Tint removal...
Old Jan 24, 2003
DMX's Avatar
DMX
DMX is an unknown quantity at this point
Tint removal...
Is it hard to take the tint off??
and how do u do it??
I got a ticket for tint and now i have to remove it... damn!!!
Old Jan 24, 2003
sadboy916's Avatar
HISPAnIC CAUSIn PAnIC
going to have to go to a place that does tint about 80-100 bucks
Old Jan 24, 2003
4bangin's Avatar
damn dude, you are getting a ticket for everything.
Old Jan 24, 2003
RunawaySoul's Avatar
RunawaySoul is an unknown quantity at this point
My younger brother has had his stripped twice. From my knowledge, it doesn't cost much. He voluntarily stripped his btw... For $160, he had his 20% tint stripped and 5% put in. He has a sedan...
Old Jan 24, 2003
Mbow's Avatar
If you are real lucky, you can pull the tint from a corner and the glue will come off with it. You have to pull VERY slowly and have the Almightly looking over you.
Otherwise, pull it off and break out the razor blades. I had a couple windows come off cleanly when I did my accord several yrs ago. The other windows, I soaked a rag in gasoline and ran it over the window and then proceeded to scrape the goo off.
I didn't do the back window for fear of messing up the defrost. It had faded so it didn't need to come off. I was stripping the tint because I got 2 tickets for no inspection. I couldn't get an inspection because my 2 small rear windows (coupe) were too dark.
It's not hard to do and I usually prefer to save the money and do most things myself. It's your call.
Old Jan 26, 2003
CivicRicer02's Avatar
CivicRicer02 is an unknown quantity at this point
iam so glad we dont have inspections
Old Jan 26, 2003
misio4's Avatar
misio4 is an unknown quantity at this point
If you want to save 80-100 bucks do it yourself. I did mine on my old hatchback. Peal it off with a razor. Any glue left take water or windex spray, wait some secs and scrape it off with the razor. You way want to use some force. The glue on the windows made my hads heart by saved some $$$
Old Jan 26, 2003
Friedrice's Avatar
Friedrice is an unknown quantity at this point
at autozone type stores in the tint aisle, there is a spray especially for tint removal, I used it and removed the tint without leaving too much glue crap on the window, its just hard to get the corners. You spray it on, then put a trashbag or something on the window and let it sit, then it should peel off fairly easily.
Old Jan 26, 2003
dragoon's Avatar
i believe warming it up with a hairdryer first helps also
Old Jan 29, 2003
Dagooseisloose's Avatar
Dagooseisloose is an unknown quantity at this point
Be careful for the back window because you will rip the defroster apart. My friend did it on his car and unfortunately I bought his car and low and behold no rear defroster.
Old Jan 29, 2003
MyOtherRideIsBritney's Avatar
MyOtherRideIsBritney is an unknown quantity at this point
I just got mine tinted, and they told me not to use any ammonia-based cleaners to wash my windows or else the tinting would be damaged. I believe (I'm not a chem major, so bear with me) that the ammonia is a solvent and it interacts with the glue holding on the tint.
So using this knowledge, use a cleaner that DOES contain ammonia in order to make the tint break down easier.
IMO though, I think the best bet would be to go through a tint shop and have them remove it. Yes it will cost money, but it will look good, and save you time and frustration and possible damage to your window.
Old Jan 29, 2003
FALKEN's Avatar
Civicforums Junkie
Seriously...If you don't have experience with tint, just have a shop do it.
If you did have experience, then you would know that you should 'bag it' (at least the rear w/defroster) [IMG]i/expressions/demon.gif[/IMG]
BTW...Ammonia takes a long time to break down tint since it only effects the 'glue' which is on the other side of the film that your spraying it on. It will effect it faster if there were cuts or nics in it though
GolNat
Nov 27, 2018 03:32 PM
Mad Dog Tannen
Oct 19, 2016 08:12 PM
UltraHDGames
Jun 8, 2016 05:16 PM
wingsfan19
Oct 1, 2015 03:45 AM
eebing
Sep 12, 2015 05:35 AM
