Crankcase breather & AEM CAI
Old Jan 24, 2003
ImmortalEX's Avatar
Super Member
ImmortalEX is an unknown quantity at this point
Hola Mi Amigos,
I tossed on a crankcase breather & I have a AEM CAI.
Question to those who know, What did you use to cap the Hole in the CAI??
I know they pretty much dont do much, but I got one anyway.
If possible, could you post a pic of how yours is set up? I cut the hose from the CAI & fit it on the breather. I will post a pic in the morning of how I got mine on. Just want to make sure its on right.
TIA.
Late.
Old Jan 24, 2003
01civicboi's Avatar
01civicboi is an unknown quantity at this point
it might not look supernice, but you could just wrap it with electrical tape [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Jan 24, 2003
ImmortalEX's Avatar
Super Member
That is what I did to get home.
But I do need to cap it or something. Maybe get another breather for the CAI??
Old Jan 24, 2003
CapYoda's Avatar
Escaped Convict
getting a breather is pointless...
in fact if you go to get your smog check that wont pass emission since the PCV isn't connected to the intake... and er... you might have oil spit out from around the breather...
slapping the breather on the CAI is even more pointless...
I suggest going to the hardware store and find a plug.
Old Jan 24, 2003
asianmatrix02's Avatar
asianmatrix02 is an unknown quantity at this point
what is the point of the aftermarket breather anyways?? for looks? and if oil would spill out of the aftermarket breather, then in stock form would oil go into the intake??
Old Jan 24, 2003
IDQcivic's Avatar
IDQcivic should not be trusted
I think the point is so that the CAI would only be getting cold air directly through the filter, and no air that leaves the crankcase. If you put a breather on the intake it would be getting hotter air closer to the engine. Honestly, I think it would be mostly for looks in my opinion. Maybe you could go to a hardware store and find some kind of rubber plug that would fit tightly in the intake hole. I tried a beather once, but couldn't get it to fit properly, so I just said forget it.
Old Jan 24, 2003
Rider's Avatar
Rider is an unknown quantity at this point
Like IDQcivic told...just try to find some kind of rubber plug that would fit tightly in the intake hole. I found some at an hardware store near my home...like 1$ or 2$ ... those are some rubber to put on the kitchen I think...and it look nice and clean!
Have a look at this pic ...
http://www.pbase.com/image/6757415
This is not the best quality pic to see the breather but...just to help you to see what I am talking about!!
Eric
Old Jan 24, 2003
orso's Avatar
orso is an unknown quantity at this point
yes the oil would run back into the intake. that is the main reason to get the breather to keep the oil out of the tb thus keepinig it cleaner. the other reason is because with the tube attaching the intake pipe to the valve cover it can create a small amount of pressure. eith the breather it lets everything breath freely.
Old Jan 24, 2003
ImmortalEX's Avatar
Super Member
Ok, rubber plug it is. My understanding of the breather is this:
With the normal set up (tube from valve cover to CAI), That the hot air from the engine would be getting sucked into the intake, thus not truly getting 100% cold air (like you get 100% anyway [IMG]i/expressions/face-icon-small-wink.gif[/IMG] ). With the breather, you done have that hot air from the engine sucked in, blah blah.. Hell, I might just buy anothe rhose & put it the way it was. [IMG]i/expressions/face-icon-small-smile.gif[/IMG], I will try the plug first Though.
Here is a pic of what it looks like @ the moment
Old Jan 24, 2003
Connie's Avatar
My AEM CAI made a huge difference in sound and a relativly large difference in performance also, then again it is -9 here today....what was the question again?
Old Jan 24, 2003
ImmortalEX's Avatar
Super Member
The point of that reply was?? [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Jan 24, 2003
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
Your not going to notice any differenc if the breather is on or you
have the crankcase tube attatched to the intake.
Old Jan 24, 2003
ImmortalEX's Avatar
Super Member
I kind of figured that. But I want it on there (at least for now)
Old Jan 24, 2003
Jaykuai's Avatar
ish...
isn't the pont of the breather to give a chance to the engine to "survive" when the CAI filter is underwater?
Old Jan 24, 2003
ImmortalEX's Avatar
Super Member
Nah, That is the by Pass valve.
Anyway, I just put everything back to how it was.
and capyoda was right. When I took it off, there was a bit of oil inside the breather. Eventually over time it probably would build up & leak out the filter.
Old Jan 24, 2003
Baghead's Avatar
Baghead is an unknown quantity at this point
you do know that not recirculating crank case fumes back into the throttlebody is illegal right?
also, i feel sorry for you on a hot day if your car fills with gas fumes.
Old Jan 24, 2003
HondaSales's Avatar
HondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of light
when i bought a universal shift **** it came with different size rubber stoppers to go over the threads on top of the shifter lever. i used one of those rubber stoppers and it fit right over the hole on the intake pipe.
Old Jan 26, 2003
silverghost's Avatar
silverghost is an unknown quantity at this point
Ok guys... Here's the whole purpose behind the little tube that runs from the valve cover to the intake. The throttle body (the part your intake is attached to) is subjected to the harsh climate of moisture, warm and cold air as well as whatever dirt gets past the filter. The purpose of this little tube is actually a dual pupose.
1. To aid the the positive crankcase ventilation system (PCV)
2. The tube allows a small amout of oil to enter the throttle body thus lubricating it and preventing the
effects of the aforementioned harsh environment from seizing the the whole assembly.
In short... leave the tube hooked up. It's put there from the factory for a reason... and the manufacturer of the aftermarket put the fitting on thier product for the same reason.
Hope this helps you out a little! [IMG]i/expressions/face-icon-small-cool.gif[/IMG]
Old Jan 26, 2003
Corrosion's Avatar
Corrosion is an unknown quantity at this point
Thanks for saving me from some masked flaming on the PCV hose issue and the long detailed explanation. YES! Leave it on for it serves a very serious purpose.
carid
Nov 7, 2015 01:46 AM
naokigoffi
Aug 30, 2015 06:19 PM
spyder13
Jul 31, 2015 06:31 PM
Misfit2613
Jul 30, 2015 09:49 AM
Theshwartz35
Jul 17, 2015 11:13 PM
