To: Black99CivicEx regarding fuel reg
Old Jan 22, 2003
Pinoyexposed's Avatar
Pinoyexposed is an unknown quantity at this point
I saw in your members ride you had an adjustable fuel pressure regulator, can you post a DIY on how you installed it. My friend and I was confused when he bought an adjustable fuel reg because it says on the connection that it needs a connection to the return hose and also a connection to the vacuum hose of the throttle body. Can you help us? I know you did some modifications on your AFPR. Tnks for your help man and good luck on your motor project[IMG]i/expressions/beer_yum.gif[/IMG]
Old Jan 22, 2003
cambo's Avatar
I wish I was asian
he converted from return-less fuel system to a return fuel system
also...use PM.
also...starting threads to/about black99vtec has traditionally started flame wars....so i'd try not to start threads like these.
Old Jan 22, 2003
Elite's Avatar
Elite is an unknown quantity at this point
lol what he said... use PM
Old Jan 23, 2003
AR's Avatar
AR
e-married to daydreamer
read camboo's sig. that should shed some light. [IMG]i/expressions/laugh2.gif[/IMG]
Old Jan 24, 2003
Can you post your ride Cambo? I wanna see your ride dude
Old Jan 24, 2003
Black99Vtec's Avatar
first member with a d16 swap
Black99Vtec should not be trustedBlack99Vtec should not be trustedBlack99Vtec should not be trusted
U CAN USE THE FPR WITH OUT DOING A RETURN LINE. OUR MOTORS DONOT HAVE VACUME LINES LIKE THE OLDER ONES. JUST PLUG UP THE RETURN LINE OUTA THE FPR AND CAP THE VACUME LINE. AND JUST RUN THE FUEL LINE INTO THE FPR AND THEN OUT AND IN TO THE RAIL. MAKE SENCE
Old Jan 27, 2003
Tnks dude
cwisenbaker06
Aug 19, 2015 04:29 PM
Civicircus
Aug 6, 2015 11:58 PM
Green02civic
Jul 27, 2015 10:48 PM
