Location of Fuel Pressure Regulator?
Old Jan 17, 2003
XxPloSiv2k1Lx's Avatar
XxPloSiv2k1Lx is an unknown quantity at this point
Having trouble locating this...
Old Jan 17, 2003
Ichiban's Avatar
Ichiban is an unknown quantity at this point
For the 7th gen I'm pretty sure its right by the gas tank. And I think I read somewhere that the fuel pump and the pressure regulator is the same unit.
Old Jan 17, 2003
orso's Avatar
orso is an unknown quantity at this point
Quote
[hr]Originally posted by: AznThug08
For the 7th gen I'm pretty sure its right by the gas tank. And I think I read somewhere that the fuel pump and the pressure regulator is the same unit.[hr]
exactly
Old Jan 17, 2003
PlatCruiser's Avatar
PlatCruiser is an unknown quantity at this point
I don't think the regulator and fuel pump can be one unit. If thats the case then both the fuel pump and regulator are external of the tank, or is the pump in the tank and the reg outside the tank, or are both the pump and the reg in-tank?
Old Jan 17, 2003
orso's Avatar
it is of my understanding that they are both inside of the fuel tank and they are both combined into one unit.
Old Jan 18, 2003
well i asked Black99vtec and he said theres one located near the fuel rail..this just makes me more confused..but he seemed to be the only one that had alot of experience with the D17 motors till this day....thanks everyone!! everyones help is appreciated!!
Old Jan 18, 2003
Pinoy3LeR's Avatar
Pinoy3LeR is an unknown quantity at this point
its located near the fuel rail,it looks like a small vacuum,it is not located at the gas tank,the fuel pump and the fuel regulator are different units,fuel pump,pumps fuel from the gas tank to the fuel regulator which controls the amount of pressure coming from the fuel pump
Old Jan 19, 2003
smack the head all you want. heh
On a neon ( I know I don't want to hear it ) anyway they come with a returnless fuel system and both the regulator and pump are in the tank. You simply have to block the regulator from the fuel and install the reg of choice I use aeromotive and drill a bulk head fitting into the tank. Seal it up and run the hose of choice from the reg to the fuel tank and bingo return fuel system.
Old Jan 22, 2003
Pinoy3LeR's Avatar
yeah right [IMG]i/expressions/moon.gif[/IMG]prove it
Old Jan 22, 2003
prove what?
Old Jan 22, 2003
HP's Avatar
HP
HP is an unknown quantity at this point
Okay people, F marks the spot! [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
And all this of course is located in the fuel tank.
Old Jan 22, 2003
and I'm betting its a 2 pieces, one for pump one for reg. I also bet if I could get ahold of one of these it would be easy to make a return fuel system.
I'm not gonna buy one though or take off my brother tank to find out though
Old Jan 22, 2003
HP's Avatar
HP
Here's a better pic of the actual regulator
Basically looks to be a regular regulator just with a short return line
Old Jan 22, 2003
ok so basically you would have to block the regulater from regulating but still allow it to flow fuel down the fuel line to the fuel rail. Then from the rail run a line to the new adjustable regulator. Then run the return line off the regulator back to the tank where you would drill the fitting and seal. You can put the new regulator before or after the fuel rail, it does not matter.
mrcell24
May 19, 2015 10:02 AM
JoeB16
61
Oct 16, 2003 07:58 PM
Cross
16
Feb 28, 2002 10:34 PM
ripper
Jan 28, 2002 02:00 PM
MooCoW
Nov 15, 2001 10:58 AM
