HID Question
Old Jan 12, 2003
Polaris's Avatar
Polaris is an unknown quantity at this point
HID Question
Please help. What size HID should I get?
I have TYC projectors on order, but I need to order my HID systems now... what size should I get H4 9003 H1?
anyone who has done this please let me know what you did, and how pleased or not pleased you are with it.
thanks
-Michael
Old Jan 12, 2003
CarbonFly's Avatar
H1 D2S is what works the best from what I hear. Because you are getting TYC's, you will need an H1 bulb.
This is Unleaded's HID kit that he got off of E-bay. Low's only.
Old Jan 12, 2003
Polaris's Avatar
I was lookinb to see if I could get a dual beam kit... anyone have any ideas on where?
so TYC's use H1's. ok.. thanks =)
-Michael
P.S. anyone seen a H1, low and high beam kit?
Old Jan 12, 2003
2k2civicRAY's Avatar
2k2civicRAY is an unknown quantity at this point
So are you asking if there is a HID kit that uses one bulb for the low beam, that is also functional as a high beam in H1. Well no. Most of the time you don't need brights with HIDs, but it won't be hard to wire in the high beam projector thats already present to work.
Or are you asking if there is a HID kit that has one set of bulbs for low beams and another set for high beams. No. A lot of places sell a hid kit for 600. And thas the kind I just mentioned above. If you want something like this. Go on ebay and buy 2 hid kits. I posted a link to hid kits on ebay earlier this week and netbc has the kit on ebay that is 299. He said it is very bright and very good quality. So If you want Hids in your low beam projectors AND Hids in your high beam projectors, go on ebay and get 2 kits for basically the price of one at many other shops.
Ray
Old Jan 12, 2003
Polaris's Avatar
Ok, thanks Kappa, you answered my question perfectly....
so they dont make a HID kit with one set of bulbs for low and another set for hi...
Would I still be able to put H1 Silverstars in my Projectors Hi beam spot, in case I ever wanted to turn them on?
would that still work the same?
and I think I found a HID kit I want.... I was just worried that it said low beams only...
-Michael
P.S. Also, how do you wire up TYC projectors? H1 bulb in low beam spot and H1 projector in hi beam spot? (do I have to rewire the whole setup?
because we have H4's which run off one bulb...
Old Jan 12, 2003
CarbonFly's Avatar
Quote
[hr]Originally posted by: Polaris
because we have H4's which run off one bulb...[hr]
I have the TYC's also. It comes with a wiring harness that plugs right into the existing plug. No modification needed.
Old Jan 12, 2003
Polaris's Avatar
Thanks guys, you both are awesome...
All these answers helped a lot..
now I am just trying to find a H1 D2S system..... I can only find d2r systems.... grrr.....
Old Jan 12, 2003
Just do it Ebay
Old Jan 12, 2003
XxJDMCivicxX's Avatar
This is gonna sound like stupid question but I might as well ask are HID kits street legal?
Old Jan 12, 2003
CarbonFly's Avatar
Quote
[hr]Originally posted by: XxJDMCivicxX
This is gonna sound like stupid question but I might as well ask are HID kits street legal?[hr]
They had better be, or else BMW and Mercedes and other companies are breaking the law.
Old Jan 12, 2003
SLAMMED01CIV's Avatar
SLAMMED01CIV is an unknown quantity at this point
Ok I'm going to straighten this out right now. I had TYC projectors and both the high beam and low beam bulbs are different. They are not both H1. The low beam is in fact an H3, but the high beam is H1. If you're buying an HID kit for the low beam you will have to look for a bulb similar to an H3.
Old Jan 12, 2003
SDE's Avatar
SDE
SDE is an unknown quantity at this point
My TYC Projector's Use H1 For Both Hi & Low Beam...
Old Jan 12, 2003
CarbonFly's Avatar
Quote
[hr]Originally posted by: SDE
My TYC Projector's Use H1 For Both Hi & Low Beam...[hr]
same here
Old Jan 12, 2003
Hefe's Avatar
Second Place is the First Loser
Hefe is a jewel in the roughHefe is a jewel in the roughHefe is a jewel in the rough
Quote
[hr]Originally posted by: FlyRiceRacer02
Quote
They had better be, or else BMW and Mercedes and other companies are breaking the law.[hr]
OEM HID are legal... But i think almost all aftermarket HID are in fact illegal
Old Jan 12, 2003
dragoon's Avatar
Quote
-Michael
i believe projectors come with a wiring harness that goes into the factory plug. i wouldn't know since i don't own any, though. you could get two sets of HID's, though it'd be a good idea to get new wires, as HID's draw more current when igniting. also, switching to another set of HID for hi beams would be almost totally useless because it takes a few seconds or more for the bulb to fully "warm up", making it impossible to "flash" others instantly. they do make dual-beam HID's for h4 applications. SPW uses a reflector that shifts when you switch to hi beams to project the beam further. they use hella ballasts and osram bulbs. raybrig japan also makes something similar, but of much higher quality, and much higher price. i have seen the raybrigs first hand on a car at my sponsor's shop, and those things are hot however, i would recommend for you to have HID for your lows, and regular H1 bulbs for your highs.
tuvok
Sep 25, 2015 03:13 PM
JMKendrick
Sep 16, 2015 06:17 PM
junkyardguy
Sep 2, 2015 06:07 PM
herbiej
22
Aug 23, 2015 01:02 PM
martinsmartin
Aug 15, 2015 07:34 PM
