Maintanence required?
Old Jan 4, 2003
Civicccc's Avatar
Civicccc will become famous soon enoughCivicccc will become famous soon enough
I know that after a while the -maint req'd- light will blink when you start the car, when you need an oil change. I have not had a chance to change the oil, but now the light stays lit. Is it because I need to change my oil. Or does it only stay lit when there is a problem with the car. I always thought it would only blink to remind you of the oil change.
Old Jan 4, 2003
Pinoy3LeR's Avatar
Pinoy3LeR is an unknown quantity at this point
ask your honda mechanic,try to check your engine oil if its really dark,then change your oil
Old Jan 4, 2003
Mbow's Avatar
It comes on according to set intervals that you can look up in your owner's manual. They aren't really for "oil changes" per se, but for semi- or complete services such as inspecting the car for any problems and such. The owner's manual will also tell you how to reset that annoying light. I never do those services as they are a huge waste of money.
Old Jan 4, 2003
vtecbabe01's Avatar
vtecbabe01 is an unknown quantity at this point
As the others said, it's just a reminder. Nothing is wrong. I just had mine reset yesterday. I believe that it blinks until it's 10k since your last service and then it stays lit. It explains it all in the manual.
Old Jan 4, 2003
2001civ's Avatar
2001civ is an unknown quantity at this point
yeah comes on at 8,000 miles to tell you that you have a 10,000 mile check up on the way and mine came on again at 17,000 reminding me to do a 20,000 check up. I do them myself but are things like oil changes and rotate tires. check the fluids... It's different at each interval but your manual lists what you should do at each one.
EDIT: the check engine light comes on if there is actually something wrong with the car and you should scan the codes to see whats wrong where as the mat'n required light is the maintenance schedule reminder.
Old Jan 6, 2003
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
How do you reset the maintenance light?
I've tried unplugging the battery, but that does not seem to work
Old Jan 8, 2003
xzykotic's Avatar
xzykotic is an unknown quantity at this point
Yeah, at 8000 miles I was like "What the fudge?!" Then I read that it blinks when you start your car after 8000 miles for 10 seconds. Then after 10000 miles, it stays lit. I got annoyed and reset it after I called and found out that "routine maintence" was like 125 beans just for an oil change, tire rotation, and some other useless junk.
Old Jan 21, 2003
Jzero's Avatar
Jzero is an unknown quantity at this point
Quote
[hr]Originally posted by: xzykotic
Yeah, at 8000 miles I was like "What the fudge?!" Then I read that it blinks when you start your car after 8000 miles for 10 seconds. Then after 10000 miles, it stays lit. I got annoyed and reset it after I called and found out that "routine maintence" was like 125 beans just for an oil change, tire rotation, and some other useless junk.[hr]
Cripes...where do you people get your service done? I paid $35 for 10k service last month...oil change, rotate tires, check fluids. Although the normal oil change is $25 so they are still basically charging you $10 to rotate the tires while it's up on the lift.
But still....$125? That's just nuts.
Old Jan 22, 2003
OyD's Avatar
OyD
OyD is an unknown quantity at this point
RTFM
Old Jan 29, 2003
LOXLEY's Avatar
LOXLEY is an unknown quantity at this point
well this has been a popular problem. i just did this a few weeks ago. everything in the manual is correct except for one tiny detail. you have to make sure you odometer reading is showing and not your A and B trip setting. once you've done that just follow the manual. and you should be good to go.
carid
Sep 28, 2015 10:13 AM
Bruce2
Sep 21, 2015 08:01 PM
