01 EX manual transmition ECU and Automatic Transmition ECU the same?
Old Dec 30, 2002
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
Hey guys,
I have a JET PERFORMANCE re-programmed ECU. (that's how I am in the
15.7's)
I was wondering if an 01 automatic coupe ECU is the same as the 01 manual
transmition coupe ECU?
I need to have a stock one since I am going to be running N20 and the JET
Performance re-programmed ECU has the timing advanced.
What do you think? Should I swap ECU's back to OEM specs or should
I get an adjustable cam gear to retard the timing back.
I need help!!!
Old Dec 31, 2002
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
a cam gear adjusts cam timing not igniton...you'll need to get the ECU adjusted
Old Dec 31, 2002
kjgracing's Avatar
CRAP!!!
I guess I need an OEM ECU then...
where is the best place to get one or trade with someone.
I need OEM so I can run nitrous.. advanced ignition timing
equals detonation equals good bye engine
Old Dec 31, 2002
HondaLuver's Avatar
Its a celebration bitches!
This is the reason i did not get chipped, i got the V-AFC instead so it can control my fuel better. there are still a few problems with it even though the right wiring diagram is up....
Markwnjr
Turbo
Jun 25, 2015 06:36 PM
MegaBassX
Jun 11, 2015 08:52 AM
cruisers10
May 12, 2015 10:46 PM
oneheadlight
Apr 29, 2015 11:30 PM
McD
Apr 22, 2015 05:28 PM
