Need suggestions on camber kit
I just bought rims (205/40/17 changing to 215/45/17)and neuspeed sport springs front lowered to 1.75" and back 1.6" right now im riding on my stock hubcaps winter tires I haven't put the springs on yet and I was wondering how bad will the camber be with the stock hubcaps and when i put the rims on will it kill my tires badly. What's a good camber kit for a good price and should i get rear only or front and rear?
odd yer front will drop farther than your rear..
usually it's the other way around to level off the car..
but either way..i'm 1.6 front and 1.7 rear and all i'd personally worry about (if i ever do worry) will be the back..
the front sits beautifully, and actually grips better the harder and faster i go into a turn..
the back's got a bit of an angle and i'm thinking about doing it..
SPC over Ingalls imo, and both run about the same price of $250 for the pair for rears..(as i've been quoted..just for parts..)
Just dropped my car on some H&R sports, the fronts look fine but the camber in the rears are a bit off. I'm putting on my rims in the spring and I'll put on a camber kit as well. I think rears are a definate change, but fronts I dunno. Up to you if you want to spend $$$. Don't forget you Koni's!
I also plan on getting koni's I plan to install this all in the early spring. SPC I can afford now but I'm a lil short on the konis so looks like it ill be another 2 weeks till i get my next paycheck
IMO Ingalls. The front are cheaper than the back as everyone has already told you, but I don't quite remember how much I paid for my kit. Just be sure that when they are being installed or if you are installing yourself, follow the instructions! and make sure they lube them up nicely.
LiTTleMayTag
LiTTleMayTag
fecrni
Aug 8, 2015 06:15 PM
j-chest
Jul 31, 2015 01:18 PM
LorenzoC0395
Jul 14, 2015 08:46 PM
