Shaking at around 60mph???Transmission or what?
Old Dec 28, 2002
KMan's Avatar
KMan is an unknown quantity at this point
yo,
Ive noticed that my steering wheel begins to shake just past 60mph and then stops goin to 70mph, then returns shaking when decelerating through the 60's.....i dont know if its my transmission or if its tires or what??? If you know what causes this shaking let me know.... Thanks!
Kman
Email: Modesqud84@aol.com
[IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Dec 28, 2002
flotsamm's Avatar
Sounds like alignment or your tires are out of balance. Try swapping the front and rear tires around and see if it feels any different. If the problem now feels like its coming from the rear, then its most likely an out of balanced wheel. If it makes no difference, it could be an alignment issue or perhaps a driveline problem.
Old Dec 28, 2002
VTECTypeR's Avatar
Its an alignment issue for sure
Old Dec 29, 2002
KMan's Avatar
Aight thanks guys....
I will be gettin my 17's at the end of January so i will just get my alignment set and stuff when i put them on....i will just have to ignore it...THNAKS
KMAN
Old Dec 29, 2002
2Hottie's Avatar
2Hottie is an unknown quantity at this point
I had the same problem with the stock tires the other day....I drove to work the day after a bad snow...so I was running through deep snow...came out of work and everything was cleared and dry on the roadways, and it was the worst vibration I have ever felt in the car! I couldn't go past 60 since it was shaking the car soooo bad....later that night, went back out it was fine...now, I know for a fact that my stock wheels are out of balance, so that is probably it as I could probably use a good alignment....
2Hottie
Old Jan 24, 2003
LOXLEY's Avatar
LOXLEY is an unknown quantity at this point
it's definately a wheel balance problem. i had the exact same thing happen to my car. got a rebalance done..... ops check good.
Old Jan 24, 2003
Friedrice's Avatar
Friedrice is an unknown quantity at this point
yeah, one of your wheel weights must've fallen off, get the wheel rebalanced
Old Jan 28, 2003
SilverCivSedan's Avatar
SilverCivSedan is an unknown quantity at this point
Alignment, balance, or could be a warped brake rotor(but not really likely) My wheels do it all the time, ever since i got rims, that is[IMG]i/expressions/face-icon-small-cool.gif[/IMG]
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
muniorbust
33
Aug 31, 2015 08:59 PM
lyanreindecker
Aug 20, 2015 09:15 PM
amrhamed
Aug 7, 2015 11:39 AM
brennov8
Jul 13, 2015 12:57 PM
