installing tie bar, help!
Old Dec 24, 2002
billllly's Avatar
billllly is an unknown quantity at this point
i was installing my rear lower tie bar and when i took the bolt out that holds the control arm it fell out of place. does anyone know an easy way to line the hole back up?
Old Dec 24, 2002
slammed2k2's Avatar
slammed2k2 is an unknown quantity at this point
use another jack or jack stand and put it back in place...
Old Dec 24, 2002
billllly's Avatar
tried that and it still wont line up. and the wheel even looks crooked now. i didnt think it was gonna be such a pain in the ***
Old Dec 24, 2002
Grey's Avatar
DIY King
Search this forum for threads on this topic. A lot of people have had this problem when installing it.
Here are some links:
- NEED HELP ASAP
- How 2 re-align bolts on rear lower install
- I just bought a Lower Rear Tie Bar, i need some help on exactly how to install?
Old Dec 24, 2002
ak's Avatar
ak
Retired Mod
ak can only hope to improve
You should have used a viseclamp or a jack to hold the control arm in place BEFORE taking out the bolt.
Anyway, Grey did the search for you
Old Dec 26, 2002
CelCUs's Avatar
CelCUs is an unknown quantity at this point
I posted this a few days ago cuz' i did the same thing, i'm gonna go take some pictures I'll be right back
Old Dec 26, 2002
CelCUs's Avatar
OK if you haven't gone under there that circular piece of metal is what you're trying to line up. The easiest way to get it lined up is like this:
1.) Jack up car the normal way and take off your tire.
2.) Knock the entire control arm out of there (the plastic piece that is holding that circular piece of metal.
3.) Put a jack under the control arm a little closer towards the tire from where that circular piece of metal is.
4.) Jack up the control arm HIGHER than it is supposed to go.
5.) Get the soft end of a pair of pliers or something like that, make sure the metal is covered by rubber or something, and jam it into the other side of the metal piece. (The side further away from where your tire goes. 6.) Now you can pry the control arm down a little with the soft end of the pliers.
NOTE: This probably won't work the first time, it's gonna take a few tries to get it. And also when you're jacking up the control arm it won't move at first, this is normal, once a certain amount of pressure is applied to the plastic piece holding the circular piece of metal it will budge. Pm me if you have more Q's
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] Picture 187.JPG (17 Kb)
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] Picture 420.JPG (13 Kb)
Old Dec 28, 2002
sumama's Avatar
sumama is an unknown quantity at this point
The only reason I bought a tie bar was cuz i thought it would be really easy to install. I thought I would just take off the bolts, attach the tie bar, put the bolts back on, and DONE. but dayam, i dont wanna go through all that trouble just for a tie bar. Some people are saying it took a couple hours! Selling mine now, $20 shipped!
Old Dec 28, 2002
CapYoda's Avatar
Escaped Convict
er.. just have jackstands supporting the LCA and you should be fine.
still a 10-20 min. install IMO, u just gotta do it right..
its not that difficult.
Old Dec 28, 2002
cvc2k2's Avatar
cvc2k2 is an unknown quantity at this point
i installed mine using jack stands to support the control arm. took me 30 minutes to install! isnt that bad.
Old Dec 28, 2002
CelCUs's Avatar
After I messed up on mine it only took me 30 minutes. Just jack up the car and start playing with it. Why did you even buy it if you didn't wanna spend half an hour installing it? Install that instead of watching T.V. or something. Besides you still gotta line up the holes to get the bolt through B4 you can drive your car, so just put it back through with the bar on. And when you do the other side do it right
Old Dec 29, 2002
speed werx's Avatar
speed werx is an unknown quantity at this point
jack her up....push in the wheel and hold....then use something to wedge under the arm to help mine it up as you lower the car some.....
Dorval Andre
May 1, 2015 09:37 AM
El_Spic
Apr 23, 2015 03:14 PM
Daniel420
Dec 4, 2001 08:46 PM
0100010
Bolt-on Engine Performance
Nov 26, 2001 07:50 PM
BiGbRoWn
Nov 21, 2001 06:17 PM
