ingalls rear camber making squeaking noise
a few days after i got my camber kit installed, it started making sqeaking noises whenever i go over bumps in the road. i've had my camber kit for about a month or two but i've been busy due to school and now that i'm done with my finals, i have time to work on my car. anyway, i've searched and i came up with this thread
http://www.7thgencivic.com/forum/arc...eyword1=camber
but its a pretty old post and i was wondering if anyone else has had this problem and if there are any effective ways to fix this without having to take apart the camber kit. if i just spray it with WD-40 w/out taking it apart, will it take care of the problem or just fix it temporarily? thanks in advance.
I think you know what to do? You can live with the noise and save $ on not getting another alignment. You can spray WD-worthless on them every day. Or you can take them apart and lube them with poly-grease, and go get another alignment. PS did you buy the rubber or the polyurethane?
to be honest, i'm not sure which one they are because i bought them off another member of the site, but i'm pretty sure they are the polyurethane ones because i've heard that the rubber ones do not make the squeaking noises.
It won't be that big of a deal to just spray em with wd-40 every so often. For a longer lasting solution you need to talk with Grey. Send him a pm or something. He should be able to help you better than I can.
