ingalls rear camber making squeaking noise
Old Dec 15, 2002
TuffVietta's Avatar
TuffVietta should not be trusted
a few days after i got my camber kit installed, it started making sqeaking noises whenever i go over bumps in the road. i've had my camber kit for about a month or two but i've been busy due to school and now that i'm done with my finals, i have time to work on my car. anyway, i've searched and i came up with this thread
http://www.7thgencivic.com/forum/arc...eyword1=camber
but its a pretty old post and i was wondering if anyone else has had this problem and if there are any effective ways to fix this without having to take apart the camber kit. if i just spray it with WD-40 w/out taking it apart, will it take care of the problem or just fix it temporarily? thanks in advance.
Old Dec 15, 2002
Mitch's Avatar
Mitch is an unknown quantity at this point
I think you know what to do? You can live with the noise and save $ on not getting another alignment. You can spray WD-worthless on them every day. Or you can take them apart and lube them with poly-grease, and go get another alignment. PS did you buy the rubber or the polyurethane?
Old Dec 15, 2002
Mbow's Avatar
Must have bought the poly set. I would have gotten the SPC kits if I were you. WD-40 should work and last for a couple weeks at a time I would think,
Old Dec 15, 2002
TuffVietta's Avatar
to be honest, i'm not sure which one they are because i bought them off another member of the site, but i'm pretty sure they are the polyurethane ones because i've heard that the rubber ones do not make the squeaking noises.
Old Dec 15, 2002
Mbow's Avatar
It won't be that big of a deal to just spray em with wd-40 every so often. For a longer lasting solution you need to talk with Grey. Send him a pm or something. He should be able to help you better than I can.
ghondavic
Transmission
Apr 12, 2017 09:37 PM
dennis123
May 3, 2015 03:14 PM
ernhole1
Dec 6, 2001 12:05 PM
speed werx
Nov 27, 2001 08:52 AM
JeffSpeed21
Bolt-on Engine Performance
Nov 4, 2001 12:33 PM
