Car won't start up when..............
Old Nov 9, 2002
01CivicPLanet's Avatar
01CivicPLanet is an unknown quantity at this point
Hi guyz, was up.
Okay, here we go. I had this problem in the past couple of week, I'm getting it check out on Monday and just want to know what you guyz think.
When ever I put gas on my car. I could not start up my car, (it sounds funny but it is turth) it will on start when I turn the key to start and hit the gas pattle. I was wonder what is wrong? Could it be the fuel rail?
Thx
Old Nov 9, 2002
Ike's Avatar
Ike
Ike is an unknown quantity at this point
Well it might not be a good idea to put gas on your car unless you just want a new one anyway. Oh and where is the gas pattle. Nah, just play'n. That is weird though. I dont want to get flamed for this one because it is my opinion but i think it is the fuel pump. Just an opinion, if i'm wrong dont start the hate child.
Ike
Old Nov 9, 2002
Nuts's Avatar
Nuts is an unknown quantity at this point
did you put diesel in like the other guy[IMG]i/expressions/laugh2.gif[/IMG]
Old Nov 9, 2002
Quote
[hr]Originally posted by: Nuts
did you put diesel in like the other guy[IMG]i/expressions/laugh2.gif[/IMG][hr]
NO
Old Nov 9, 2002
CrankinCivic's Avatar
CrankinCivic is an unknown quantity at this point
someone put desiel in there car ?
Old Nov 9, 2002
Desi's Avatar
Desi is an unknown quantity at this point
usually you DON'T step on the gas pedal to start a car, b/c of the fuel injection system and computer reads the engine temp to send the correct amt of fuel to start the car.
i had to do it with my old beater, 89 corolla gts, especially in the winter
one problem: did u ever just step on the gas pedal when it was just parked? b/c stepping on the gas pedal opens the throttle body when, i think, the computer wants it closed.
my guess: its the fuel injection system. it could clogged. but don't add additives/cleaners yet. wait till you get to the dealer.
Old Nov 9, 2002
SleeperCivic's Avatar
SleeperCivic is an unknown quantity at this point
What about trouble codes? Hmm, I don't think I know how to do this in our cars yet. I think I'll check that out. Anyone know if you can hook up a volt meter or something and read the codes from the engine computer?? If you can read the codes they'll probably tell you something.
Old Nov 9, 2002
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
Quote
[hr]Originally posted by: CrankinCivic
someone put desiel in there car ? [hr]
[IMG]i/expressions/laugh2.gif[/IMG]I think two people put diesel in their cars. I thought that was in a thread[IMG]i/expressions/laugh2.gif[/IMG]
As for putting gas on your car... that won't fill up the tank and can get pretty costly when you are sitting there with a tank on E and gas all over your car.
Try this if you don't already do it... turn your key to the ON position... wait 3 seconds (i think it allows your oil pressue to build up) or till you hear a click and see your gauges go up, and then turn your key to START and start her up. Just a thought though. That most likely isn't your problem but it seems like you are experiencing that kind of start. [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Nov 9, 2002
Boosted2k2's Avatar
Quote
[hr]Originally posted by: SleeperCivic
What about trouble codes? Hmm, I don't think I know how to do this in our cars yet. I think I'll check that out. Anyone know if you can hook up a volt meter or something and read the codes from the engine computer?? If you can read the codes they'll probably tell you something.[hr]
I know on a lot of cars you can check your engine codes on the ECU by turning a slot on the ecu to the opposite direction with the key in the on position and reading the blinks from the check engine light. I haven't looked at our computer yet. The only thing is when you use that slot you have to break a seal and it will void the warranty on it. I used that way to check my code on my altima also I used it to reset my check engine light when I traded in my car[IMG]i/expressions/demon.gif[/IMG]
Old Nov 10, 2002
BigHippo22's Avatar
BigHippo22 is an unknown quantity at this point
Quote
[hr]Originally posted by: Smokie2k2LX
Quote
Try this if you don't already do it... turn your key to the ON position... wait 3 seconds (i think it allows your oil pressue to build up) or till you hear a click and see your gauges go up, and then turn your key to START and start her up. Just a thought though. That most likely isn't your problem but it seems like you are experiencing that kind of start. [IMG]i/expressions/face-icon-small-confused.gif[/IMG][hr]
how would leaving the key in the on position build up oil pressure....do we have some kind of new fangle electric oil pump???
As for your problem...I don't know, but don't try anything till after you go to the dealer, is it still under warranty?
Old Nov 10, 2002
DaRickSta's Avatar
DaRickSta is an unknown quantity at this point
I've been having a "no-start" problem intermittenly for as long as I have owned my Civic. Check this: next time you start you car and it fails, see if the little green "starter disable" key is blinking. That is what is wrong with mine. The anti-theft device is working a little TOO good. I need to find time to bring all my keys to the dealership and have them reprogram the keys. Unfortunately, in the past 9 months there wasn't a time where I had free time AND all the keys on me at the same time!
I hope this kinda helps!
Braun
Apr 23, 2015 09:03 PM
Trav_02civic
Engine start problems
Apr 23, 2015 08:57 AM
SSMatey
Apr 13, 2015 06:09 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
