Check Engine Light/Gas Cap
Old Nov 6, 2002
Taffy's Avatar
Taffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant future
My Check Enigine came on while I was driving last night and I was freaking out. Someone told me to check the gas cap and when I did, I figured it was the cause of the light coming on because I did not close it tightly.
How long does it take for the light to go off after I tightened it back up?
Old Nov 7, 2002
CarbonFly's Avatar
You have to tighten down the cap until it clicks 3 times.
Old Nov 7, 2002
BrotherSound's Avatar
BrotherSound is an unknown quantity at this point
i would think after you tightend it with 3 clicks it should go off? if not thats weird
Old Nov 8, 2002
2Hottie's Avatar
2Hottie is an unknown quantity at this point
Quote
[hr]Originally posted by: BrotherSound
i would think after you tightend it with 3 clicks it should go off? if not thats weird[hr]
3 clicks is the trick! If you didn't do the 3 clicks, be prepared to make a trip to your local Honda dealer to get the light reset....the only way I was told it can be done...
2Hottie
Old Jan 4, 2003
Steveo's Avatar
Steveo is an unknown quantity at this point
Just open the hood, and take out the 7.5 amp memory fuse, and wait 10seconds, then put it back in....problem solved dude!
Steveo
Old Jan 29, 2003
LOXLEY's Avatar
LOXLEY is an unknown quantity at this point
the check engine light is programmed to come on. read the manual it will explain this and how to get rid of the light. but the manual left out one tiny detail. make sure your odometer reading is showing and not your A and B trip setting before you go through the motions to reset the light.
Old Feb 21, 2003
noahnoah's Avatar
noahnoah is an unknown quantity at this point
Quote
[hr]Originally posted by: LOXLEY
the check engine light is programmed to come on. read the manual it will explain this and how to get rid of the light. but the manual left out one tiny detail. make sure your odometer reading is showing and not your A and B trip setting before you go through the motions to reset the light.[hr]
I think you're talking about the maintenance required light, not the CHECK ENGINE light. The manual doesn't say how to reset the CHECK ENGINE light. If it does I don't know where.
Xuhme
21
Aug 7, 2023 03:40 PM
thana
Jun 15, 2020 07:05 PM
mistermenphis22
Apr 3, 2016 08:06 AM
deus-ex
Apr 13, 2015 12:29 PM
bahena08
Apr 11, 2015 05:09 PM
