Install sidemarkers? Watch out for rust!
Old Nov 4, 2002
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
2 months after the install, I figured i'd look around the sidemarker hole for rust. I put some touch-up paint around the edges when I first installed them, but I knew I didn't do too good of a job..
Sure enough. I went and put touch-up paint around the entire hole this time and waited for it to dry before snapping them back in place.
Old Nov 4, 2002
speedracersong's Avatar
i want to put in some sidemarkers but im too scared to cut into my own car.
Old Nov 4, 2002
Blackflys2001's Avatar
Blackflys2001 is an unknown quantity at this point
I have JDM sidemarkers off of an S2000 on mine.. most body shops will cut the holes for $20-30
Old Nov 4, 2002
2001CIVICLX's Avatar
2001CIVICLX is an unknown quantity at this point
Quote
[hr]Originally posted by: Blackflys2001
I have JDM sidemarkers off of an S2000 on mine.. most body shops will cut the holes for $20-30[hr]
Would most gaurantee against rust?
Old Nov 4, 2002
MSoft's Avatar
MSoft is an unknown quantity at this point
If you want to prevent rust, you should put rust-proofing primer on before the touchup paint. That goes for dents and scratches that goes to the metal too.
Old Nov 4, 2002
Boilermaker1's Avatar
Jap-Euro Fusion
If you still have some room to play with... you may want to put a wire wheel in a dremel and clean off the rust before you cover it back over. Hopefully there's still enough room around the edges of the sidemarker before the hole starts to poke out around the edges. Some rubber striping around it, or between the fender and the marker to keep the water out.
Old Nov 4, 2002
silverdevil's Avatar
silverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of light
Yes, but even keeping the water out won't keep the moisture out. Humidity is a biotch and will sneak in there anyways. It will take longer to rust but eventually it will as well. The best thing to do is grind it down with a dremel and put rust proof primer and touch up paint. Rustoleum makes a good primer foru outdoor patio furniture that should work great.
Old Nov 4, 2002
CarbonFly's Avatar
I'm not planning on my putting sidemarkers on my car. I would rather have smooth lines with nothing interrupting the flow. Ahhh, How I dream of the day when I get my door handles shaved.
Old Nov 4, 2002
AzNmiKex215's Avatar
2k1civic.com O. G.
my uncle is a mechanic and he did my side markers for me.. he put some kinda of jelly type stuff around the edges where the hole was cut.. no rust till this day its been more then a year now!
Old Nov 4, 2002
Spoonman's Avatar
Spoonman is an unknown quantity at this point
Since you already have a little rust I would recommend a product called OneStep. You can put this stuff right over top of rust (although I would suggest cleaning it off). I goes on as a white liquid and dries shiny black. excellent stuff.
civicPRODIGY
Nov 12, 2001 09:32 PM
