Why does it keep revving?
Old Oct 30, 2002
SMX's Avatar
SMX
SMX is on a distinguished road
I've never owned a car that revved down so slow after letting off the gas. It winds up quickly, so I'm guessing it's not flywheel mass. Is it a lean burn condition when the throttle is lifted?
Old Oct 30, 2002
DowntownRicer's Avatar
DowntownRicer is an unknown quantity at this point
You know i have the same problem, i dont know why it does it.
It's like if you hold the throttle steady for a good bit, then let up, the thing falls to like 2000 or under.
BTW: I also have a weird problem in the rain also. Whenever i hit a good enough poddle of water its, like something splashes up and the engine makes this hard grindy sound, sounds like its trying to clear somethin out of the intakes or somethin, i was thinking that the water may have been getting sucked in, but that would cause the engine to stall wouldnt it?
Old Oct 30, 2002
Duckor's Avatar
Duckor is an unknown quantity at this point
downtown, its been happening to many many members on this site.. Derek even started a thread that became huge. I don't think honda has said anything about this yet tho.
Old Oct 30, 2002
CivicManDan2's Avatar
CivicManDan2 is an unknown quantity at this point
when you let off the gas does it stay "stuck" at around 2k rpms and then fall or is it just slow to fall.
Old Oct 30, 2002
LJ's Avatar
LJ
Fernando The Donkey Lover
LJ is an unknown quantity at this point
Quote
[hr]Originally posted by: DowntownRicer
BTW: I also have a weird problem in the rain also. Whenever i hit a good enough poddle of water its, like something splashes up and the engine makes this hard grindy sound, sounds like its trying to clear somethin out of the intakes or somethin, i was thinking that the water may have been getting sucked in, but that would cause the engine to stall wouldnt it?[hr]
I ahve that too, it freaks me out!
Old Oct 30, 2002
JJJ's Avatar
JJJ
JJJ is an unknown quantity at this point
I have a 2k2 auto, when I rev the engine a bit it is just slow to go back to regular RPMs. I thought I was the only one!!
Old Oct 30, 2002
LikeWEEEEEEEEEE's Avatar
LikeWEEEEEEEEEE is an unknown quantity at this point
this is the built in anti-stall feature...something wants to bring your car down, so the ecu gives it some gas.
its more common in cold weather.
Old Oct 31, 2002
ducksause's Avatar
ducksause is an unknown quantity at this point
I have the same problem and it's not new to honda civics I've own three different civics in my time and they all did that. it's the strangest thing.[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Oct 31, 2002
IDQcivic's Avatar
IDQcivic should not be trusted
mine does something like that too.. say if I'm driving and come to a stop and shift to neutral, it it will like drop down to say 750 and then jump back up to 1500, then jump down to like 650, backup to 1400, and it jump back and froth like 3-4 times before it idles at about 500.. It seems like it did that when the weather changed but now its not doing it as much, maybe the ECU needs to adjust to the colder weather...
solarpunk70
Apr 12, 2016 11:43 AM
Solo Flow
Oct 4, 2015 07:52 AM
Yang559
Transmission
Sep 21, 2015 01:41 PM
Bricoleur
Sep 9, 2015 12:30 PM
Uan
Aug 23, 2015 03:03 AM
