Parking Break Porb......
Old Oct 28, 2002
ZSKCivic01's Avatar
Extreme Member
ZSKCivic01 is an unknown quantity at this point
Hey everyone, just got my front brake pads changed this weekend cause they were going out. I didn't need new shoes though for the rear breaks. Just yesterday when I tried to use my parking break when parked on an incline, the brake barely went up. It went up far enough to were the break light came on, but it doesn't go even close to as far up as it did before I got my brakes changed. Is this normal with new brakes, or is something wrong?
Old Oct 28, 2002
4Saris's Avatar
4Saris is an unknown quantity at this point
It is normal after an adjustment. The calipers just have to move less to be just as tight. The sensor is based on the position of the calipers not the brake handle inside the car.
Old Oct 28, 2002
Boilermaker1's Avatar
Jap-Euro Fusion
Quote
[hr]Originally posted by: 4Saris
It is normal after an adjustment. The calipers just have to move less to be just as tight. The sensor is based on the position of the calipers not the brake handle inside the car.[hr]
The e-brake has nothing to do with the front brakes. It only applies force to the rears. Chances are they adjusted your e-brake cable too, and made it too tight. It should still work no problem as long as the light comes on, it is applying force, but if it bothers you that it doesn't come up higher, take it back and get it loosened a little bit so it comes up more.
Old Oct 28, 2002
DaCurryman's Avatar
DaCurryman is an unknown quantity at this point
Quote
[hr]Originally posted by: Boilermaker1
Quote
The e-brake has nothing to do with the front brakes. It only applies force to the rears. Chances are they adjusted your e-brake cable too, and made it too tight. It should still work no problem as long as the light comes on, it is applying force, but if it bothers you that it doesn't come up higher, take it back and get it loosened a little bit so it comes up more.[hr]
Correct! =) When I got my regular services done, they adjusted my e-brake cable as well. If it bother's you, don't worry, it'll loosen up pretty quick. Mine was back to the way it was in a matter of 3 weeks or so.
Old May 25, 2003
odie's Avatar
odie is an unknown quantity at this point
Has anyone here ever tightened or adjusted the parking brake cable yourself?
nirvanaguy
25
Oct 26, 2017 07:26 PM
siliconvalley
Sep 15, 2015 09:48 PM
NaturalSelectio
Sep 6, 2015 06:59 PM
KikAzz
Sep 4, 2015 12:36 PM
junkyardguy
Sep 2, 2015 06:07 PM
