Front Camber kit
Front Camber kit
cant u just use a bolt and nut for the front for our car. i seen how the front camber kit look like. it just look like a bolt and nut
The Standard One
looks can be disceiving.. our stock is just a bolt.. why not just add a washer to it, it just doesnt work that way... the front camber kit isnt just a regular bolt. but then you dont even really need it so.. and its what 20 bucks
I'm trying to figure this out, I don't know much about suspension, but I am planning on lowering about 1.5 inches front and back. I don't really drive hard, but I know that I will need a front upper strut bar, right? Are you guys saying that I won't need a front camber kit? How about a rear camber kit? How about a rear strut bar (upper or lower?)
[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
The Standard One
you dont really NEED anything. but they are recommended. reason why you dont really need the front is we have mcpherson struts and the camber is hardly effected. even with a 1.75" drop your camber will probably within spec. as for the rear, it is recommended with most drops. its almost a must once you go past 2.25" unless if you want to replace your tires 3 times a year. i know aswzero will recommend you get strut bars when you drop your car but i dont think its necessary. but ya nothing is really NEEDed, some are [highly] recommended tho.
