Front Camber kit
Old Oct 26, 2002
DizWikedCivic's Avatar
Front Camber kit
cant u just use a bolt and nut for the front for our car. i seen how the front camber kit look like. it just look like a bolt and nut
Old Oct 26, 2002
VNlilMAN's Avatar
The Standard One
looks can be disceiving.. our stock is just a bolt.. why not just add a washer to it, it just doesnt work that way... the front camber kit isnt just a regular bolt. but then you dont even really need it so.. and its what 20 bucks
Old Oct 26, 2002
yea tru we dont really need a front camber kit, but i was just curious
Old Oct 28, 2002
ASWZero's Avatar
ASWZero is an unknown quantity at this point
If you really like to slam your car, you will need a camber kit to bring the camber in and go even lower.
Old Oct 28, 2002
andyman97's Avatar
Turbo Guru
I'm trying to figure this out, I don't know much about suspension, but I am planning on lowering about 1.5 inches front and back. I don't really drive hard, but I know that I will need a front upper strut bar, right? Are you guys saying that I won't need a front camber kit? How about a rear camber kit? How about a rear strut bar (upper or lower?)
[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Oct 28, 2002
VNlilMAN's Avatar
The Standard One
you dont really NEED anything. but they are recommended. reason why you dont really need the front is we have mcpherson struts and the camber is hardly effected. even with a 1.75" drop your camber will probably within spec. as for the rear, it is recommended with most drops. its almost a must once you go past 2.25" unless if you want to replace your tires 3 times a year. i know aswzero will recommend you get strut bars when you drop your car but i dont think its necessary. but ya nothing is really NEEDed, some are [highly] recommended tho.
Makeice3498
Jul 2, 2015 11:13 AM
ernhole1
Dec 6, 2001 12:05 PM
speed werx
Nov 27, 2001 08:52 AM
JeffSpeed21
Nov 4, 2001 10:32 PM
ImmortalEX
Oct 31, 2001 10:00 PM
