How to install neuspeed upper front strut
Old Oct 25, 2002
01SOHCcivic's Avatar
01SOHCcivic is an unknown quantity at this point
I just got my strut today but the instructions is not in the bag along with the other papers
oh well no biggie
what do I need to do to install this thing?
Old Oct 25, 2002
netcbc's Avatar
netcbc is an unknown quantity at this point
pretty basic, just screw it ontop your strut towers, not sure if thats the right term
Old Oct 25, 2002
AzNmiKex215's Avatar
2k1civic.com O. G.
were did u get it from and how much did u pay?
Old Oct 26, 2002
Boilermaker1's Avatar
Jap-Euro Fusion
Unscrew the 2 outer bolts on each tower. Put the right side on first. Then try to fit the left on. If the left side doesn't just drop on, jack up the car just a little (enough to stretch out the springs) and try to get it to fit on. It eventually will fall on. Put the nuts back on and torque them to 33 ft-lbs (just make them tight)
That's basically what the sheet says.
Old Oct 26, 2002
InanimateCarbonRod's Avatar
InanimateCarbonRod will become famous soon enoughInanimateCarbonRod will become famous soon enough
If you have to do the jack up thing, loosening the 3rd nut helps. Drop the bar onto the studs, lower the car, tighten all 6 nuts.
Old Oct 26, 2002
Roadog's Avatar
Roadog is an unknown quantity at this point
Quote
[hr]Originally posted by: AzNmiKex215
were did u get it from and how much did u pay?[hr]
Rob at www.tornactive.com has them for $100.00 I haven't seen them for any less....
Old Oct 26, 2002
AFlyer's Avatar
AFlyer is an unknown quantity at this point
um, it's about as basic as it gets, you couldn't figure it out just by looking at it?? unscrew nuts from strut towers, put bar on bolts at each end, replace nuts. that's about the easiest install you could do.
Old Oct 26, 2002
nbpEMCivic's Avatar
nbpEMCivic is an unknown quantity at this point
Quote
[hr]Originally posted by: Boilermaker1
That's basically what the sheet says.[hr]
There's 3 bolts on each strut tower. And its very stimple. Unsrcrew all 6 bolts, put the par in place, put the bolts back on, take it out for a test drive.
Old Oct 26, 2002
CapYoda's Avatar
Escaped Convict
well if he has a 5spd he'll need to move the clutch fluid or relocate it...
they come with a nut so you can relocate it.. but its kinda tough cuz you'll have to reach through the fenderwell...
Old Oct 27, 2002
Jap-Euro Fusion
Quote
[hr]Quote
[hr]
You only need to pull the 3rd if the bar doesn't fit on after pulling off just 2. Basically. if you need to jack it up to fit it on, loosen the 3rd one, you don't need to completely remove it.
Quote
[hr]well if he has a 5spd he'll need to move the clutch fluid or relocate it...
[hr]
The nut is only needed on 01's, for 02+ just bend the bracket forward a little bit.
Old Oct 27, 2002
specificcivic's Avatar
specificcivic is an unknown quantity at this point
[IMG]i/expressions/demon.gif[/IMG][IMG]i/expressions/face-icon-small-puke.gif[/IMG]
For 1, I live in Canada and have had a hell of a time finding the neuspeed strut tower bar...Anyone know of any Canadian places where I can buy this application?
For 2, I have a 01 and would like to know if any of u have any pics as to where I am supposed to remount this clutch fluid resevior w/ the screw that comes w/ the bar.
Old Oct 27, 2002
nbpEMCivic's Avatar
Here is my strut tower...3 bolts..thats my old strut bar. All 3 of the bolts had to be removed.
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] strut tower 1.jpg (17 Kb)
Old Oct 28, 2002
Danni's Avatar
Danni is an unknown quantity at this point
I have a 5 speed, and I didn't have to relocate my klutch fluid
beachglass
Jun 1, 2015 08:28 PM
honda200192
May 31, 2015 05:57 PM
beachglass
May 22, 2015 09:59 PM
GH04si
Apr 15, 2015 08:13 PM
andylao
Nov 4, 2001 01:19 PM
