port and polish?!?
Old Oct 18, 2002
royce's Avatar
royce is an unknown quantity at this point
port and polish?!?
what does port and polish do anyways? with it would my car get faster?
Old Oct 18, 2002
ExRacer's Avatar
ExRacer is an unknown quantity at this point
better performance.
Old Oct 18, 2002
AZ2K1Civic's Avatar
yup
Old Oct 18, 2002
PerfectD3's Avatar
PerfectD3 is an unknown quantity at this point
This allows for more efficient breathing within the engine. HP increases may be significant if done by a professional. Make sure to have it done by a professional, if there are any nicks remaining, detonation may occur. This may cause major problems problems in the head.
Taken from the net using Yahoo search terms "port and polish"
Old Oct 18, 2002
DatJuice's Avatar
DatJuice is an unknown quantity at this point
ya ull have better "performance" in the high end but ur low end will see a slight drop.
Old Oct 18, 2002
SoNiCcIvIc's Avatar
SoNiCcIvIc is an unknown quantity at this point
Port and polished from Honda.
Old Oct 18, 2002
PRCIVIC2001's Avatar
PRCIVIC2001 is an unknown quantity at this point
Port and Polish really doesn't do much for you unless you have all basic boltons I/H/E. Cams and pulleys can help too.
Old Oct 19, 2002
royce's Avatar
Quote
[hr]ya ull have better "performance" in the high end but ur low end will see a slight drop.[hr]
what do you mean by a slight drop on the low end?
Old Oct 19, 2002
mohawkboom's Avatar
Because air flows more rapidly..low end torque may decrease a little...it's a good mod though. It allows faster airflow into the cylinders..
Old Oct 19, 2002
1955's Avatar
a high rev engine doesnt have much low end torque b/c the short push rods.prcivic was right about havin a larger profile cam and crank ...etc to use in conjucntion with a ported/polished head. to port /polish a head is to remove the metal in the intake/exhaust ports to make them breath more air in and out( a camshaft makes that determination).polishing the ports is makin the surface smooth for air flow,other factor is the ability of the ignition to provide the exact amount of fuel/sparks to burn in the combustion chambers,a honest machine shop owner will more likely to tell u not to waste the money b/c the head of the civic engine does not have much metal left to gain a significant amount of power.
Old Oct 20, 2002
mohawkboom's Avatar
Correction.. No performance shop or machin shop will actually polish the intake or exhaust ports.. an overly smooth sufrace actually increases air resistance.. this is why golf ***** have dimples..
the term port and polish has been around since the 50's when Heads were made of Cast iron and the intake ports and such were often pitted and needed to polished down even after increasing the bore..
A Proper headjob leaves the ports with a machined finish..if you ran your fingernails over it it would feel a little bumpy/scratchy...
the Proper terminology for this wpuld actually be port work..as there is no polishing involved.. [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Oct 21, 2002
Barney's Avatar
Barney should not be trustedBarney should not be trustedBarney should not be trusted
Correction,
When they port the head they have to polish it down. It becomes very ruff and sharp edges that could cause uneven air flow or gas exhaust or intake air leaks. I had it done to my head and that id how they explained it to me. One of you were right. They said the isn't to much gain, but the most I would get with all other mods would be .01 to .04 on your quater slip. Later
burnyd
ECU Fried
May 24, 2018 10:44 PM
Mad Dog Tannen
Oct 19, 2016 08:12 PM
99BoostedSi
Sep 7, 2015 04:49 PM
user 84948
Air Conditioning
40
Jul 10, 2015 07:08 PM
Ccoop87
Jul 9, 2015 03:26 PM
