help got big problems
Old Oct 16, 2002
Black99Vtec's Avatar
first member with a d16 swap
Black99Vtec should not be trustedBlack99Vtec should not be trustedBlack99Vtec should not be trusted
i am trying to put on this unorthodox crank pully and my stock one will not come off. i have used a impact gun and a 6 foot breaker bar and i torched the hell out of it and used penetrating oils ( get ur mind out of the gutter) haha but nothing will budge the bolt. so i decided to drill out the bolt and just take off the head of the bolt but man that thing is made out of some serious metal ,this concrete hard core drill my dads got didnt put a scratch on it . the bolt must have like welded its self to my crank shaft. i think i am facked i dont know what to do next no one at any dealers knows either. any ideas?? i have a glitch in my jet ecu i think and every one ina while i miss 4th gear and take it to 9k or 10 k rpms i am thinking i might have spunn it or heated it up to much and melted it
Old Oct 16, 2002
01civicboi's Avatar
01civicboi is an unknown quantity at this point
Quote
[hr]Originally posted by: Black99Vtec
i am trying to put on this unorthodox crank pully and my stock one will not come off. i have used a impact gun and a 6 foot breaker bar and i torched the hell out of it and used penetrating oils ( get ur mind out of the gutter) haha but nothing will budge the bolt. so i decided to drill out the bolt and just take off the head of the bolt but man that thing is made out of some serious metal ,this concrete hard core drill my dads got didnt put a scratch on it . the bolt must have like welded its self to my crank shaft. i think i am facked i dont know what to do next no one at any dealers knows either. any ideas?? i have a glitch in my jet ecu i think and every one ina while i miss 4th gear and take it to 9k or 10 k rpms i am thinking i might have spunn it or heated it up to much and melted it[hr]
OMG i've never seen so much BS in one paragraph and sig
Old Oct 16, 2002
JohnnyLee's Avatar
7thgen guh chee
Wat happend?
Old Oct 16, 2002
Youthachak's Avatar
Youthachak is an unknown quantity at this point
Quote
[hr]Originally posted by: 01civicboi
Quote
[hr]
I think hes refering to a 6th gen civic.[IMG]i/expressions/face-icon-small-confused.gif[/IMG] Notice the "99" in between black and vtec.
Old Oct 16, 2002
silverdevil's Avatar
silverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of light
Well dude, if a 6 foot breaker bar and lot's of force didn't budge it then I think you're about sol. I could break the torque on hells gates with a 6 foot breaker bar.
Old Oct 16, 2002
aki's Avatar
aki
aki is an unknown quantity at this point
Quote
[hr]Originally posted by: Youthachak
Quote
Quote
[hr]
I think hes refering to a 6th gen civic.[IMG]i/expressions/face-icon-small-confused.gif[/IMG] Notice the "99" in between black and vtec.[hr]
No if you read his earlier threads he has a 7th gen. But yes, his claims don't seem very legit.
-Aki
Old Oct 16, 2002
nochopstix's Avatar
nochopstix is an unknown quantity at this point
if you reved your engine to 9 or 10k rpm your engine would be blown. thats bs
Old Oct 16, 2002
speedracersong's Avatar
Quote
[hr]Originally posted by: aki
Quote
Quote
Quote
[hr]
-Aki[hr]
i dont think that guy knows what gen he has. he has to have a sixth gen... and taking a car up to 9k-10k... im not aware of 6th gen or 7th gen civic motor doing that no matter what u have done to it.
Old Oct 16, 2002
IDQcivic's Avatar
IDQcivic should not be trusted
I like how he says "torched the hell out of it...." what did he use a flamethrower???? perhaps he means TORQUE!!!
Old Oct 16, 2002
solar's Avatar
solar is an unknown quantity at this point
I'm not sure but I believe the bolt you're trying to remove has a reversed thread, try going the opposite direction and see what happens.
Old Oct 16, 2002
lagger's Avatar
lagger is an unknown quantity at this point
ok .. i said this before, but i'll say this again. get a crank pulley holder. they are a GOD SEND! $62+ shipping from snapon, but well worth it IMO.
those bolts are notorious for not coming off, almost as bad as axel nuts. they are torqued to 136ft/lb on a b series motor. DO NOT drill out that bolt, you will get yourself into more trouble than it's worth. if you can't take it off w/ a 600ft/lb impact wrench or a breaker bar w/ a 6ft cheater bar, imagine trying to get the rest of the bolt out with an ez-out.
with the crank pulley holder and the breaker bar, i guarantee that you will get it off. may snap the breaker bar, but it WILL come off.
also when you put it back on, make sure that you torque it to spec, good and tight is not good enough. and don't loose the little shim that locks the pulley into place on the crank, it's tiny, and very easy to misplace.
Old Oct 16, 2002
thanks lagger i will try it. i appreciate all the help man . every one else on here r full of it and just like to rag on every one
Old Oct 17, 2002
PlatCruiser's Avatar
PlatCruiser is an unknown quantity at this point
try putting the car in 5th, having a friend stepping on the brakes, and go back at it with the breaker bar.
GolNat
Suspension DIY
May 12, 2022 06:49 AM
7thgensurvivor
38
Aug 29, 2015 11:50 AM
beveragemp
May 25, 2015 07:11 PM
bsmiley
Apr 27, 2015 01:27 PM
civicPRODIGY
Nov 12, 2001 09:32 PM
