Sponsored by:
Sponsored by: CARiD
concern:cleared headlights
Old Oct 15, 2002
rijowysock's Avatar
ThE FaMiLy SeDaN
i cleared my headlamps like about 3 months ago and havent had any moisture what so ever in them until today i noticed small amount of moisture on the botttom where the main lamp is and in corners of other 2 lamps its not dripping or anything inside just condensation for now. i know its prolly becuase its been raining for the past week or so. but will the moisture go away or is there any way i can get rid of it without taking the bumper and headlights out and apart again. (i.e. can i just heat em up with hair dryer or something like that?) anyways thanx for taking your time to read my post.reply with your best way to defog the headlamps.
riley
Old Oct 15, 2002
ShadyMilkMan's Avatar
ShadyMilkMan is an unknown quantity at this point
just leave em it will go away
Old Oct 15, 2002
TYPE7RS's Avatar
TYPE7RS is an unknown quantity at this point
the head light itself gets pretty hot, but if you leave the headlight in there, the bulb i mean, the moister can't escape. that's a tough one. the only sure-fire way i can think of would be to remove the head light assembely and pop it in the oven for a bit, that way the moisture can and will escape the headlight
a hair drier might work, but i think it would take forever to do.
Old Oct 15, 2002
Importracer's Avatar
Importracer will become famous soon enoughImportracer will become famous soon enough
umm, i would definately take the bumper off, and take the headlights off the car and reseal them because i had just a little bit of moisture comming into the headlights and i was blowing my PIAAS left and right, once i resealed them i didnt kill any of my Piaas and they work fine. SO i suggest you do that.
Old Oct 15, 2002
XxPloSiv2k1Lx's Avatar
XxPloSiv2k1Lx is an unknown quantity at this point
i used a heat gun and it worked pretty good...its similar to a hair dryer but more stronger and hotter!!
Old Oct 15, 2002
Bartkat's Avatar
Might as well reseal them. If you have a leak now and dry them out, then it's going to leak again. You will ger more condensation as the weather changes.
Old Oct 15, 2002
RedDragon333's Avatar
i would go the extra mile and take them off and reseal them but you could always leave them and as the heat up in the sun that will more than likly get rid of it
Old Oct 16, 2002
CivicGoh's Avatar
CivicGoh is an unknown quantity at this point
Just drill two holes on da bottom of the housing so the condensation can drip out.
It works, trust me
Old Oct 16, 2002
Macker's Avatar
Macker is an unknown quantity at this point
Do you reseal the holes up again [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Oct 16, 2002
you can but itll look like crap! better to take them off and reseal them!
Old Oct 16, 2002
Bartkat's Avatar
One little thought. Make sure those little rubber booties are on the back of the headlights where the bulbs plug in. Those have to be tight and sealed to keep moisture from entering from behind the bulbs.
Old Oct 16, 2002
CivicGoh's Avatar
no u dun reseal the holes or else the condensation will build up again its there so the condensation can be let out
no one will notice because no one sticks there nose up to ur light n looks for holes
meicalnissyen
Sep 25, 2015 12:12 AM
rnaodm
Sep 21, 2015 12:42 PM
shaejb15
Sep 12, 2015 01:02 AM
Bricoleur
Sep 9, 2015 12:23 PM
MamaBear2015
Sep 4, 2015 09:04 PM
