clutch problem
Old Oct 14, 2002
Silversleeper's Avatar
Silversleeper is an unknown quantity at this point
clutch problem
lately ive noticed that when, from a stop, i begin to move in first gear, while releasing the clutch the idle tends to wana drop dramatically. the clutch engages/disengages farther away from the ground than it used to. and when its just about to release, it seems like it wants to stall the motor. i have to rev more to keep everything smooth. this really becomes a problem going uphill. i fear my clutch will need replacement soon. i only have about 9500 miles. i dont race much, havent even been to the track yet. has the clutch self-adjusted itself or something? need some opinions.
Old Oct 15, 2002
solar's Avatar
solar is an unknown quantity at this point
Do you give it a little gas as you let out the clutch, or do you just slowly let the clutch out and then give the gas? Your problem you mentioned with the clutch engaging farther from the floor than it used to is normal. Everyone I've talk to on this site mentioned the same thing. There is no adjustment on the clutch itself, the only adjustment is the clutch pedal height but it won't change the performance of your clutch. I also have 10,000 miles on my car, and the clutch is the same way.
dinsum
May 28, 2015 09:30 PM
pantdino
15
May 13, 2015 02:22 PM
crowtoo
May 11, 2015 06:50 PM
CaptainAmerica
Feb 3, 2002 09:36 PM
delacampos
Transmission
Jan 2, 2002 02:06 PM
