injectors!!!!!!!!!
Old Oct 10, 2002
Purple2001Civic's Avatar
Purple2001Civic is an unknown quantity at this point
injectors!!!!!!!!!
ok this is the second time my injectors have clogged up on me. all i did was run a tank of 93 octane through it . three days later the car starts running bad. i put injector cleaner in it to clear up the problem, and guess the shiit doesn't work that good cause now it missing . i talked to the honda dealer where i live and they are goig to look at it this morning. hope it all come out good cause i hate to go off on them done there . would like to know if anyone else has had any problems with there?
Old Oct 10, 2002
solar's Avatar
solar is an unknown quantity at this point
R U sure its your injectors, because in order for injectors to have a problem the fuel filter is probably really clogged which would cause the problem you mentioned. BTW that injector cleaner you add to the tank doesn't work, believe me on this one, i used to be a mechanic and the only way to clean injectors is to disconnect the fuel pump, remove the input fuel line and hook up a injector cleaner pump to the fuel rail that runs to your injectors. If this is the second time you have had that problem its probably the gas your buying, try buying gas from a very busy gas station, that insures that at least your getting "fresh" fuel and not some fuel thats been sitting in the ground collecting condensation (water).
Old Oct 10, 2002
Boilermaker1's Avatar
Jap-Euro Fusion
If you have a broken injector, then your engine will be shaking like hell, and you will feel it in the car. It would be running unbalanced. Our maxima had a busted injector (at about 115K) and the engine was running rough as hell because it was only shooting 5 Cylinders. Chances are you've got some crummy gas. If you've got a broken or clogged injector already, something is very wrong.
Old Oct 10, 2002
IDQcivic's Avatar
IDQcivic should not be trusted
I had a problem like this a couple weeks back, I took out my spark plugs and they were kinda loose, there was this brown crap on them too, i dont think they were making contact with the coils, I cleaned them up, made sure they were tight, and now it has been running fine.
Old Oct 10, 2002
PESTLNC's Avatar
PESTLNC is an unknown quantity at this point
Chevron Techron works...and use 87 octane. 93 doesn't clean any better.
Old Oct 23, 2002
well the car started running fine the morning i went to bring it down there. lastnight i started it up and it is running bad again i'm going to remove the plugs when i get home to see if that is what the problem is. thanks for all of yall's input on this!!!!!!!!!!!!!!!!!
Old Oct 23, 2002
IDQcivic's Avatar
Why are you putting 93 octane in, there is no need for that in our cars... just put the cheapest gas in and save the money you won't notice any difference and it looks like its causeing problems, so I am not sure why you keep doing it.
Old Oct 24, 2002
i was paying attention when i put the 93 in it. i thought i was putting 87 until i got done pumping the gas. i guess from now on ill just make sure it is 87 instead of 93
runawaykinms
15
Mar 22, 2019 10:32 AM
Dave Brabant
Sep 27, 2015 09:43 PM
Luluharp
Sep 27, 2015 11:56 AM
Bruce2
Sep 21, 2015 08:01 PM
Donahue
Sep 9, 2015 05:55 PM
