Tie bar usefulness?
Old Oct 9, 2002
Boilermaker1's Avatar
Jap-Euro Fusion
Tie bar usefulness?
The tie bar does go here right? So then what does it actually do? It bolts between 2 points on the same piece of metal! I'm not sure that it would do anything at all. So what's the deal? Does it keep the suspension from moving front and back? or what? I'm just not seeing what it does.[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Oct 9, 2002
Silver2k1Dood's Avatar
Silver2k1Dood is an unknown quantity at this point
Quote
[hr]Originally posted by: Boilermaker1
The tie bar does go here right? So then what does it actually do? It bolts between 2 points on the same piece of metal! I'm not sure that it would do anything at all. So what's the deal? Does it keep the suspension from moving front and back? or what? I'm just not seeing what it does.[IMG]i/expressions/face-icon-small-confused.gif[/IMG][hr]
It purposefully liberates your wallet of excess weight.[IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Seriously, that one would be more for looks. Although theoretically, if you look at the crossmember, it's shaped like an inverted "U", and it could flex and twist. So a tie bar would tie the two ends together and close the gap, minimizing or eliminating any flex/twist from that point in the chassis.
Old Oct 9, 2002
01civicboi's Avatar
01civicboi is an unknown quantity at this point
I installed my DC tie bar and the RSX-S sway bar at the same time and i DID notice a difference. More so than just a front strut bar
I'm pretty sure you could get the same results with a no-name tie bar, assuming that it fits
Old Oct 9, 2002
macrossranma's Avatar
macrossranma is an unknown quantity at this point
its the sway bar that made the difference, hey, did u use the rsx enlinks or your use your stock enlink for the sway bar?and other than the sway bar, what other parts u need to get to install it?
Old Oct 9, 2002
yess24's Avatar
yess24 is an unknown quantity at this point
What is a sway bar? Thanks.. [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Oct 9, 2002
Simkin's Avatar
Simkin is an unknown quantity at this point
It keeps the crossmember from flexing, and prevents undue stress. You only really 'NEED' it if you are upgrading your rear anti-sway bar over 20mm.
Old Oct 9, 2002
Jap-Euro Fusion
It keeps it from flexing along which axis? I'm assuming it keeps it from twisting along the line of the axle...
Old Oct 9, 2002
robbclark1's Avatar
Retired suspension supermod.
This is IDQ's car. The big bar that says Progress on it, is a tie bar. It controls the flex between the crossmember. The big 22mm round bars is in front of the bar, is a sway bar. The EX comes with a 12mm one but can be upgraded to a 19 or 22mm one. That also helps to control the flex of the rear but on the outer parts of the car, near the struts and wheels.
Old Oct 9, 2002
IDQcivic's Avatar
IDQcivic should not be trusted
Hey man thanks for steeling my picture
GolNat
Suspension DIY
May 12, 2022 06:49 AM
Dorval Andre
May 1, 2015 09:37 AM
Daniel420
Dec 4, 2001 08:46 PM
0100010
Bolt-on Engine Performance
Nov 26, 2001 07:50 PM
BiGbRoWn
Nov 21, 2001 06:17 PM
