VAFC Question!
Old Oct 6, 2002
MyCivic's Avatar
MyCivic is an unknown quantity at this point
VAFC Question!
To all of the gurus with the knowledge [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
1.Did your check engine light came up after you hooked up the cables from VAFC to MAP Sensor?? Or I did something wrong??
2. The Tach cable can be connected to the blue wire that is located on the passangers front fender?? Or I am missing something?
And please do not write that I should look up in DIY because I looked and read and got lost.
Thanks[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Oct 6, 2002
Nuts's Avatar
Nuts is an unknown quantity at this point
look it up in the DIY section man!...[IMG]i/expressions/laugh2.gif[/IMG]....j\k....i dunno i've never installed one before. i'm glab to be of no help.
Old Oct 6, 2002
MyCivic's Avatar
And one more thing!
My Revs are not working on the dashboard at all!!! And my Revs on my VAFC are opposite, it shows around 5000 something all the time. Did I get the wrong cables?
Old Oct 7, 2002
Boost's Avatar
Boost is an unknown quantity at this point
you can connnect all the wires as per the instructions just dont hook up the vtec solonoid wires. you cant change when it engages b/c we have i-vtec. thats probally why your getting the check engine. unhook it reset your ecu by disconnecting the battery for 15mins while holding the break for 30 seconds. if your still haveing problem, with the revs check all your settings and make sure you have the pramaters entered correctly <#of cylenders, sensor type ect.
Old Oct 7, 2002
MyCivic's Avatar
Cool , I am going to check that. But I got my Check Engine light before i hooked up my Vtec sensor.
Old Oct 7, 2002
Mokushi's Avatar
Mokushi is an unknown quantity at this point
Quote
[hr]you cant change when it engages b/c we have i-vtec[hr]
Boost, we don't have i-vtec. That's in the K motors. We have the same old vanilla vtec.
Old Oct 7, 2002
Nuts's Avatar
i-VTEC???????????????????[IMG]i/expressions/laugh2.gif[/IMG]. oh ok. sweet. i didn't know i had an i-VTEC in my D17.
Old Oct 7, 2002
Mokushi's Avatar
From what I have heard from members on this site that have a VAFC, is that you CAN change the engagement point. But you can't make dramatic changes to it, ie a smaller window to tune it.
Old Oct 8, 2002
MyCivic's Avatar
I am so pissed !!! I spenf freaking 4 hours hooking it up and my friend found a place that will do it for you for 75 dolla!!!!! Damn it !! Thay are proffesional import store too!!! Ahhh!
Old Oct 9, 2002
NBPCivic's Avatar
NBPCivic is an unknown quantity at this point
what is the name of the shop? i am in the chicago area as well and was thinking of getting one.
Old Oct 12, 2002
Wanger's Avatar
Wanger is an unknown quantity at this point
try this, straight from www.apexi.com
http://www.apexi-usa.com/productdocu...ivicEXVAFC.pdf
Old Oct 13, 2002
Quiksilver09's Avatar
Quiksilver09 is an unknown quantity at this point
ok i had the same problem with mine, fact is the rpm wire for the vafc which in the DIY it says connect to the light blue wire. THAT IS NOT CORRECT. On the same harness at the ecu you have to hook it up to the dark blue solid wire. I had mine on the light blue and then my check engine light came on. So check that. as for the v-tec solenoid it works just don't change the engagement point too much. I dropped mine 500 rpm and it's fine. but it's something you need to play around with. If you have any questions PM me or email me.
Old Jan 23, 2003
iNjEnCiViCmAn's Avatar
iNjEnCiViCmAn is an unknown quantity at this point
See ... im confused , what is the DIY im not at all new to this , but i just recieved my V-AFC controller and i had no installation Instructions with it , so if someone could answer that for me i would like to get started as soon as possible hooking it up , thanks...
Old Jan 23, 2003
Hwoody77's Avatar
Hwoody77 can only hope to improve
Injencivic, what do you need to know?
robjcivic
Mar 12, 2017 12:10 PM
JMKendrick
Sep 16, 2015 06:17 PM
Bricoleur
Sep 9, 2015 12:23 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
junkyardguy
Sep 2, 2015 06:07 PM
