Sponsored by:
Sponsored by: CARiD
DX gauge upgrade for $95
Old Oct 2, 2002
civic4dr2001's Avatar
civic4dr2001 is an unknown quantity at this point
link there ya go
Old Oct 2, 2002
ak's Avatar
ak
Retired Mod
ak can only hope to improve
Starting bid $20...wow. Pretty cheap IMO.
Maybe he tried putting indiglow gauges and the needles need calibration. [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Oct 2, 2002
taz757's Avatar
This would be bad if you did this as your odometer would not be reading 'true' mileage. If you were replacing your gauges, you'd have to have the dealer write down the mileage and stick it in your car on the door jam. I'm pretty sure this would also deduct from your trade-in value too.
Old Oct 2, 2002
IDQcivic's Avatar
IDQcivic should not be trusted
The ECU keeps track of the milage, if you switch the gauges it will read the same reading since we have digital odometers. If you had an old style gauge then I could see where you are coming from.....
Old Oct 2, 2002
pounds's Avatar
pounds is an unknown quantity at this point
what if someone reset their ECU, would that change the mileage reading??
Old Oct 2, 2002
theguysmiley's Avatar
theguysmiley is an unknown quantity at this point
Quote
[hr]Originally posted by: pounds
what if someone reset their ECU, would that change the mileage reading??[hr]
I think there is some sort of backup system for the mileage. But I'm not positive.
Old Oct 2, 2002
Unleaded's Avatar
Unleaded is an unknown quantity at this point
the ecu doesn't completely keep track of the odometer. trust me, i've plugged in another cluster to check the mileage of it and it reads a different mileage that is not of mine.
you can retain the 'orginal' mileage of your car when swapping cluster by buying one that has a higher mileage than your current one. when your car reaches the exact same mileage of the new cluster that's when you do the swap.
Old Oct 2, 2002
taz757's Avatar
Quote
[hr]Originally posted by: IDQcivic
The ECU keeps track of the milage, if you switch the gauges it will read the same reading since we have digital odometers. If you had an old style gauge then I could see where you are coming from.....[hr]
If memory serves me correctly, this is not true. When the 2k1s came out, there was quite a problem with the gas gauge on the clusters. Well, Honda was replacing the whole cluster and the odometer was reset back to 0. I believe the part about the ECU keeping the milage though, it just won't display on the cluster.
Old Oct 2, 2002
Jeff's Avatar
Jeff is an unknown quantity at this point
hey guys, if you buy this cluster it is ment for a auto. Also I have done this swap in my dx. The milliage starts over a 0 ! The ecu does not store the milliage. if you have any questions. email me. Jgiven01@pacbell.net or you can reach me on aol user name is webbiedx
Late
Old Oct 2, 2002
Bartkat's Avatar
When you sell the car, just don't certify the mileage. I think there's a box on the form that says "I don't know if this is true mileage". Of course that may vary from state to state.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
raymondxcho
Sep 29, 2015 09:00 PM
Cam Diaz
Sep 29, 2015 07:17 PM
ktae13
Electrical
Sep 26, 2015 05:14 PM
260000milesgoal
Sep 25, 2015 07:41 PM
