Just got my 20k miles maintainance from dealer!
Well cost me about $350. [IMG]i/expressions/face-icon-small-mad.gif[/IMG] But runs smoother now. Runs like new again!
Worth it.
I would do it with regular shop but I want the Honda certified mechanics. Oh well... [IMG]i/expressions/face-icon-small-tongue.gif[/IMG]
I really think if you can find a good dealer the hondamechs are good. Here in cali it took me a long time, but I found Larry Hopkins. They just did my 10 k maintenance, yeah, it was a 100 bucks, but they re adjusted my brakes, tranny, and made my car run a little richer for my intake (yeah, they helped with a mod!) and the car all around felt like a different car when it was done. Also, if you look in your owners manual they say to change the oil but not the filter, well, they threw in a filter on mine. Ask around, find a good dealer, and it will be worth it.
Dealerships charge A LOT for regular maintenance. Basically with a 20k, a dealership will:
- change the oil + filter
- rotate tires (balancing will cost extra)
- inspect the brakes (replace if worn)
- add BG fuel additive to the fuel tank (supposed to clean the fuel injectors)
- inspect the air filter (replace if dirty)
At every 15k, manual transmissions get their fluid changed (Honda cars '95 and up should use Honda MTF, earlier cars just use regular motor oil). At every 30k, automatic transmissions get their fluid changed and the A/C filter is changed out (all cars).
There is a lot of other stuff listed in the Helm's manual that dealerships are supposed to do, like check to see if the belt tension is within specs, inspect the exhaust system for leaks, make sure certain bolts are tight, etc. We do inspect the underside of the car (including the exhaust system) to make sure everything is ok and nothing is about to fall off. But I've done plenty of 20k services for master techs and I've never physically checked belt tension or lubricated the hinges or grease or done anything else besides what I've listed above (don't blame me - I'm under strict orders to follow whatever the master tech wants me to do).
A typical service usually pays the technician about 1.1 to 1.5 hrs of flag time, even though it takes about half an hour to complete. If it was my car, I'd just do all of this stuff on my lunch break and use the service lifts at work. If you don't have access to a car lift, just take your car to Discount Tire / America's Tire to do a free tire rotation and inspect/replace everything yourself. If you need OEM brake pads or air filters, just e-mail me (aaronechang@email.com). I can buy all Honda/Acura OEM parts at pretty much cost (a hella lot cheaper than they sell it to customers).
Bottom line - regular interval maintenance is important to do, but dealerships charge way too much to do them.
Quote
[hr]- change the oil + filter
[hr]
[hr]
Check brakes- will they really go in 20k?
Fuel additive - I thought we weren't supposed to put that stuff in? But if so, you can get that at Autozone.
Check airfilter - K&N, oh well no need to do that.
Rotate tires - self, or can get rebalanced at tire store for not too much money.
Gosh... it really is worthless.
Quote
[hr]Originally posted by: Boilermaker1
oil - self
Gosh... it really is worthless.[hr]
Quote
[hr]
[hr]
On some of the higher mileage services we do stuff like replace the brake fluid and drain/replace the coolant. But at 20k, there's really not much to do.
For $350, the dealership bent you over and had their way with your wallet. Unless you make a lot of money at what you do for a living, it's probably your best bet to do most of that stuff yourself... at least I do. But some people would rather trust their car with a technician to do basic maintanance, your call
Okay, where do you get a 20,000 mile service?
On the Honda Owner Link page they say an 18,750 mile and a 22,500 mile, but no 20,000 mile...
Check it out...
OWNER LINK, 2001 Honda CIVIC LX SEDAN
Check it out...
Quote
[hr]Originally posted by: 2001CIVICLX
Check it out...
OWNER LINK, 2001 Honda CIVIC LX SEDAN[hr]
Check it out...
i dont know what ill be doing with my 20000 mile service (which is approaching) somehow i think that even if i tell them not to change my oil they will do it anyway and screw up my car bigtime (because i use AMSOIL full synth) as far as the brakes, in my experience when brakes need replacement they make this loud scretching noise, and i always change my brakes myself. i will never pay that much $ for regular service.
fire
fire
Quote
[hr]Originally posted by: FiresVTEC
fire[hr]
fire[hr]
If you start hearing the screeching noise and continue driving with it, and then all of a sudden the screeching noise stops, then you are REALLY screwed. This means that the brake pad has worn through entirely (including the metal clip) and the rotor has nothing to rub against anymore!
Quote
i dont know what ill be doing with my 20000 mile service (which is approaching) somehow i think that even if i tell them not to change my oil they will do it anyway and screw up my car bigtime (because i use AMSOIL full synth) as far as the brakes, [hr]
[IMG]i/expressions/face-icon-small-smile.gif[/IMG]. Technicians are paid the same for a particular job (a set number of 'flag hours') no matter how long it really takes. For example, an A/C installation will pay a technician 4 flag-hours. Most experienced technicians can finish this job in about 2.5 physical hours, so they come out ahead. If it takes them more than 4 physical hours, they end up losing money. On the other hand, an installation of a hard top on an S2000 pays 8 flag-hours and actually takes 8 physical hours to complete, so there's not a lot of money to be made doing it. So if you don't want an oil change done as part of a regular maintenance, well that cuts the time to complete the maintenance in half for us. $$ Cha-ching! $$
Anyways, if you prefer the technician using Amsoil synthetic oil, just bring it to the dealership and give it to them and we'll be happy to put it in for you. We really do try to perform a quality and thorough job for the customer and honestly we're not the ones trying to rip people off. Just remember that technicians don't make up these ridiculous prices on service (that's up to the dealership and the service manager); we just do the work that's asked of us.
Quote
[hr]Originally posted by: htowncivicEX
[hr]
[hr]
CarStuff
Dec 6, 2020 12:52 PM
mrohitredd
May 28, 2015 10:03 AM
izdman
May 19, 2015 03:43 PM
tylerginevan
Apr 27, 2015 12:29 PM
