Installing Windshield Wiper Nozzles on a CF Hood...
DIY King
You have to use these little clips on the underside of the CF hood. Just slip them through the slots in the stock clips to expend them and make them hold. I used little cotter pins, but you can use anything that fills those slots. BTW, to install the nozzles, just drill out a hole and then file out little notches for the nozzles clips. You have to do this because the CF hood will be thicker than the stock hood in that drilled out location, so the nozzle clips will not hold as well as they do on the stock hood.
DIY King
I drilled the holes from the top. Plus I used masking tape so that the CF wouldn't fray. Plus I used a drill bit with a centering tip. That worked very well.
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
Jul 14, 2015 03:39 PM
