Went to the track yesterday with my EX
Old Aug 16, 2002
Jimmy24's Avatar
Jimmy24 is an unknown quantity at this point
Hey guys i went to the track yesterday and I need opinions.
It was my very first time and I messed up bad, I shifted to first gear instead third gear, hhmm, I was so nervous that in the first run, I spun there in first gear all the way through 7000. I'll do better next time, I know I can!!! Here are the times:
REACTION 1.062
60FT 2.503
330FT
ET@594FT 10.088
1/8 ET 10.773
1/8 MPH 65.69
1/4 ET 16.716
1/4 MPH 83.34
what do you all think???
Old Aug 16, 2002
PoopyRay's Avatar
PoopyRay is an unknown quantity at this point
I think your lucky that your engine didnt stall, and that you didnt blow your engine. Someone here just did that doing the same thing as you with there RSX.
Old Aug 16, 2002
viciousvolpe's Avatar
viciousvolpe is an unknown quantity at this point
that time isnt that bad....how hot was it?
i ran a18.2 in my auto pos but it was over 100 degrees
u have any mods or anythin?
Old Aug 16, 2002
Jimmy24's Avatar
I would say low 90's, not sure but it is in Puerto Rico, hot weather! I know I can do better than that! I messed up a couple of times! But thanks!
Old Aug 16, 2002
Deejai35's Avatar
Deejai35 is an unknown quantity at this point
Thats a pretty good run. I ran a 1/4 ET 16.8 at 84.5 mph. I have a 5sp EX only engine mod is an Injen CAI. Plus that was my first day/second run ever on the drag strip.
Old Aug 16, 2002
UNPREDICTABLE's Avatar
UNPREDICTABLE is an unknown quantity at this point
you could work on youre reaction time it wouldnt hurt
Old Aug 16, 2002
Jimmy24's Avatar
Yeah man I know!!!, That was a big factor!!!!
Old Aug 16, 2002
RedDragon333's Avatar
Not bad not bad at all
Old Aug 16, 2002
Jimmy24's Avatar
Thanks man, I'll do better next time!
Old Aug 16, 2002
SilverBUll8's Avatar
SilverBUll8 is an unknown quantity at this point
My REACTION was .8021 and my 1/4 was 16.53
Old Aug 16, 2002
Jimmy24's Avatar
and what was your speed????
Old Aug 16, 2002
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
I think you should be going a bit quicker.
I am in the 15.7's @ 88mph down the 1/4mi
16.7 is the stock time for the EX.
Old Aug 16, 2002
Jimmy24's Avatar
What temperature and what mods?
Old Aug 16, 2002
kjgracing's Avatar
It was in the high 90's.
You can click on the little eyeglasses icon and see my webpage for mods.
or just read below.
Kev
Old Aug 16, 2002
Jimmy24's Avatar
That re-programed ecu, is that expensive, worth it, what can you say!!!
Does it make any difference, is it like a s-afc???? I used to have a v-afc and I took it off.
Old Aug 16, 2002
DogstyleEX's Avatar
DogstyleEX is an unknown quantity at this point
wait.. jimmy.. why did you take off the v-afc??? i know the vtec part didn't work.. but how come you just took it off?
Old Aug 16, 2002
Jimmy24's Avatar
Really, I got a bunch off speeding tickets. I got p@#@ off and I took couple things off and I sold them. I know is stupid!
Old Aug 16, 2002
nightkids1's Avatar
Initial D!!!!
How the hell did you run a 15.7 in your ex???????? if you were able to run a 15.7 in your ex mabey a should get a ex engine in my dx, since my dx is lighter then the ex
Old Aug 16, 2002
Jhonda's Avatar
Jhonda has a little shameless behaviour in the past
I did it in 15.9 @92 mph on the street with my g-tech
Old Aug 16, 2002
kjgracing's Avatar
See my mods? I have also been racing for about a year now and have the rythm down I am cutting .505 lights, and I drop the air pressure down to 23 psi on the stock firestones. I have the spare tire removed and about a 1/4 of gas.
Before getting the JET ECU upgrade, I was running 15.9's and 15'8's at best. I believe once I get new tires (since I can feel the car losing grip and also the tires bark in third gear) and the temperature goes down here in sacramento I should be in the 15.6's possible 15.5's .
There will be another grudge-fest on september 5th and 6th at the track where I race. Check my member ride for track info.
Old Aug 18, 2002
nightkids1's Avatar
Initial D!!!!
oh well the reson im asking is because my friend raced his auto ex and his best time was a 18.25 i dont think he knows how to drive or something because my "DX" is faster then that and i have 17" rims
Old Aug 19, 2002
i ran a 18.2 in my auto ex too
does ur friend have any mods?
i cant wait to get my pulleys on...that should help
Old Aug 20, 2002
Jimmy24's Avatar
Also there was a dx 2001 running 17.3!
Old Aug 20, 2002
mattskav's Avatar
mattskav is an unknown quantity at this point
dude, dump the clutch well into the second yellow, don't wait to see green!
Old Aug 20, 2002
Jimmy24's Avatar
I did that! But I got a foul, so I never did it again.
I just wait for the green!!
Old Aug 20, 2002
kjgracing's Avatar
a 1.0 something is a horrible reaction time.
If you have an EX the stock 1/4 mi time is 16.4
With all the mods I have done, I am getting 15'7s
Old Aug 20, 2002
Jimmy24's Avatar
Well, you say 16.4 is stock as if that time was standard!
That might change depending of a lot of factors dude!
You might run 16.2 or 16.3 if you could run down here! You never know.
I might run 16.0 if i go there, it all depends, is not like every stock ex has to run 16.4...
I haven't seen any stock ex doing 16.9 or lower (stock) here!
Old Aug 20, 2002
kjgracing's Avatar
Yeah I know that. I was running 17.3's to 17.4's when I was completely stock.
I noticed the biggest gain after the cold air intake. The headers come into play at 4100 rpm and the ECU being reprogrammed helped throught the whole power band. I can now bark the tires in third gear at around 55 mph.
I am getting some new grip, so I doubt I will be able to do that, but I think my 1/4 times will get better.
Old Sep 6, 2002
Jimmy24's Avatar
Went back again and I made 16.6 at 84mph. Need traction!!!!!
Old Sep 6, 2002
Jimmy24's Avatar
Also, I broke at least one engine mount. The engine is vibrating at idle!!![IMG]i/expressions/face-icon-small-confused.gif[/IMG]
