Went to the track yesterday with my EX
Old Sep 6, 2002
  #31
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
I too had broke the front motor mount. Took it to the dealership and
found out that it was just the bolt that ran through the front motormount. All they had to do was tighten it.
Old Sep 6, 2002
  #32
Jimmy24's Avatar
Jimmy24 is an unknown quantity at this point
Yep, I'll check if is loose but, I can see the broken rubber. Seems like our mounts are week!
Old Sep 6, 2002
  #33
AceKicker's Avatar
AceKicker is an unknown quantity at this point
hey another suggestion on ur car to run a litle better when u run on the track take off u rbypass valve and put the reuglar rubber thing on.
Old Sep 7, 2002
  #34
IDQcivic's Avatar
IDQcivic should not be trusted
I think once the bypass valve is installed it can't be removed. you have to cut the intake and then there would be a gap. you can't put the valve in between the 2 pipes because the pipes have different diameters and it won't fit. Screw the bypass valve, its for people who want to drive there car in a lake or something...
Old Sep 7, 2002
  #35
kjgracing's Avatar
The bypass valve does rob you of some horespower. Don't even use it.
There had to be a very deep puddle for you to immerse your intake fileter all the way before it can suck up water and ruin your engine. A little
rain water does not hurt. In fact there is a water kit for our throttle body to make a mist of water for the intake.
