DAYTIME RUNNING LAMPS
Old Aug 11, 2002
TaNtRuMsBeRm's Avatar
TaNtRuMsBeRm is an unknown quantity at this point
does anyone know how to disable the daytime running lamps? sometimes i just want those damn lights off!!
i also did a search but found nothing on this site... i'd appreciate any info
Old Aug 11, 2002
ak's Avatar
ak
Retired Mod
ak can only hope to improve
What? My 2k2 civic lx doesn't have daytime running lights. They've proven that daytime running lights reduce accidents.... they're not that bad.
You could just disconnect the DRL light bulbs. [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Aug 11, 2002
jrock's Avatar
jrock will become famous soon enoughjrock will become famous soon enough
my 02 civic EX doesn't have them
Old Aug 11, 2002
armageddon's Avatar
armageddon is an unknown quantity at this point
where did you buy your civic?? I have never heared of a civic comming off the line with DRL!!
Old Aug 11, 2002
illusion's Avatar
illusion is an unknown quantity at this point
in Canada they're required by law...
All they do is have the high-beams on at a lower power.
They're annoying at times... if you're ever at a drive in the facotry method to turn them off is:
- Turn off car
- Set parking break
- turn on car
the lights will stay off till you drop the break.
I'm sure it would be easy to wire a switch with a little investigation.
Old Aug 11, 2002
Travii's Avatar
Travii is an unknown quantity at this point
I remember reading that it is an option in Japan, I thought Canada as well but I am not sure.....I don't think that they came off the line or as an option in the US.
Old Aug 11, 2002
VTecnology's Avatar
VTecnology is an unknown quantity at this point
try removing the fuse. read the manual. it should tell which fuse is for the daytime lights. hope this works. unlike u guys, i want my civic to have day time lights. i dont know y i want to.
Old Aug 11, 2002
ak's Avatar
ak
Retired Mod
oh..Canadian cars have DRL...ic now
Old Aug 11, 2002
slammed2k2's Avatar
slammed2k2 is an unknown quantity at this point
Canadian models come with DRL, its a law here in Canada... anyways i removed mine and many of my friends Day time lights, u cant remove the bulb because its the same bulb as your low and high beam...so ne ways just pull out the fuse that says day time running light, or DRL on it and done, there are 2 fuses, one is for the light itself and one is for the little DRL sign in ur dash to turn off,
good luck
Old Aug 12, 2002
thanx for the help guys but i pulled both the fuses out and.. the damn lights are still on.. [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Aug 12, 2002
CoupeStylz's Avatar
Si(R) killer # 1
CoupeStylz is an unknown quantity at this point
It works, I've been running with my DRL fuse out for a year now, because DRL looks ugly yellow, and I like the stealth option at night for laying low.
stryder12
Jun 30, 2015 08:33 PM
eorlando1
May 17, 2015 11:16 AM
Hondasport01
Lighting
Jul 12, 2005 07:45 AM
sivic2k1
Jan 31, 2002 12:30 PM
cazminn
Nov 9, 2001 11:18 AM
