Would 5th gen moroso oil pan fit?
The title pretty much describes it. Just trying to prepare for a turbo. It's so much easier to get a better oil pan and have a cleaner faster intsall.
Thanks in advance,
Brian C.
Moroso part number 20908: Aluminum, Kicked-Out Sump Pan, Honda 1.6L engines
Link
or, for those who are two lazy:
Fits:1986-89Acura Integra, 1992-95 Civic EX & Si 1988-92 all Civic/CRX Si:
Fully fabricated for exceptional strength and to provide several design advantages over stock-core pan; aluminum construction is lightweight and helps dissipate heat
Dual trap-door baffles allow oil to flow into the pickup area during hard acceleration and keeps it there under braking to ensure constant oil supply and oil pressure
Double kicked-out sump increases capacity to 5.5 quarts, while maintaining stock depth for ample ground clearance
Removable sump tray allows for easy cleaning, cools and de-aerates return oil and keeps excess oil off of the rotating assembly to prevent horsepower-robbing windage
Includes 1/2" NPT bung at rear for fitting a temperature sender and 1/2" NPT bung at front for plumbing an oil return line for turbos (also includes two 1/2" NPT plugs if required)
Includes magnetic drain plug with extra copper washer, pan mounting kit with hex-drive steel studs to eliminate stripping the engine block and serrated-face flare nuts to withstand vibration
Accommodates stock pan gasket and dipstick with existing oil level marks
Never mind, I searched and saw that Moroso has a protype out, or is working on one. Thanks anyways.
Thanks in advance,
Brian C.
Link
thanks anyways, even though i already knew the answer. I changed/edited my post. That last little blurb,
"Never mind, I searched and saw that Moroso has a protype out, or is working on one. Thanks anyways."
was to show I discovered the answer to my own question; and to let anybody who stumbled onto my post know Moroso should have an oil pan out that fits our cars soon.
Peace,
Brian C.
Peace,
Brian C.
Vaguexo
Jun 13, 2015 04:11 AM
jmdcivic
May 20, 2015 09:52 PM
pheaton
May 4, 2015 08:26 PM
