Help on installing autometer tach
Old Jul 29, 2002
Nitek's Avatar
Nitek is an unknown quantity at this point
When hooking up the green one to the blue wire next to the battery; do you have to splice the wire and connect them together? Or is there a way to take off the black thing and plug both wires in? Thanx
Old Jul 29, 2002
JackTripper's Avatar
JackTripper is an unknown quantity at this point
what i did is i went to the parts store and got in line wire crimp connector. you squeeze the connector anywhere on the blue wire and then you can connected it with the another connecter in the kit.
Old Jul 29, 2002
CrankinCivic's Avatar
CrankinCivic is an unknown quantity at this point
you do not wanan t-tap things into cars,,, t-taps break the wire and then you can issues later with corrsion, improper connection , what you should do espically with the tach wire is strip the wire back , tape it , and solder, and heat shrink it ... max protection, solder will protect againinst corrosion, and tape and heat shirnk will protect the wire from grounding out ... but you just need to pardon the espression tap into the wire ..
Old Jul 30, 2002
sundogg's Avatar
sundogg is an unknown quantity at this point
That blue wire that is by the battery, runs to the gauges. So what i did was just take out the gauges and found the blue wire connected to the gauges. I just spliced it and used a butt connector and it worked like gravy baby. Hasne fvcked up on me yet
Old Jul 30, 2002
RE's Avatar
RE
RE is an unknown quantity at this point
What kind of autometer tach did you buy? I got a really inexpensive 2300 model from summit. It has a 3.75 inch face and i mounted it right in the dash.
Old Jul 30, 2002
RE's Avatar
RE
Can't see the parking brake light and low fuel light though.
Old Aug 1, 2002
Nitek's Avatar
I got and autogage gy autometer with shift lite.
Old Aug 2, 2002
civicpride's Avatar
civicpride is an unknown quantity at this point
there is about 15 blue wires, and u have to choose one and if it don't work then put a piece of tape around the wire that did not work and then try another. i did mine with a friend it works better. one of u clamps the wire on, then start ur car and rev it up and see if it works and if it don't then try another one.
Old Aug 2, 2002
wh3nw0rdsesc4pe's Avatar
wh3nw0rdsesc4pe is an unknown quantity at this point
guys connect thr RPM wire from the tach to the RPM wire on the ECU, it's the baby blue one on the top connector, there is a pic in my DIY on the S-AFC if you want to look...
OptimisticWay
46
Oct 15, 2015 02:16 PM
mrwhos
Aug 11, 2015 02:03 AM
17
Jul 23, 2015 11:48 PM
EM_WON
Jul 22, 2015 06:49 PM
sam31444
ECU Fried
Jul 20, 2015 08:31 AM
