green plug when installing my intake?..wat the?
Old Jul 29, 2002
Speedracer720's Avatar
Speedracer720 is an unknown quantity at this point
when i removed my stock airbox there was this green plug i had to disconnect from it...and when i put on the new intake i forgot about it...it drove perfectly normal..but i just rememberd bout it and i duno where the hell it plugs into..and what it is...some1 help meeeeee
Old Jul 29, 2002
dragoon's Avatar
is it the airflow sensor?
Old Jul 29, 2002
DogstyleEX's Avatar
DogstyleEX is an unknown quantity at this point
you mean your o2 sensor? well you proly should plug it in because you're not getting an accurate reading because the engine might be different than the air you're getting from your intake.. it's to the right of the throttle body right?
Old Jul 29, 2002
01civ01's Avatar
01civ01 is an unknown quantity at this point
o2 sensor is on the exhaust, he's talking a bout the air flow meter. it plugs into the intake, there should be a little hole with a rubber grommet.
Old Jul 29, 2002
DogstyleEX's Avatar
oops.. that's what i meant..
Old Jul 29, 2002
no its not the air flow sensor..i plugged that back in..i dont know what it was..it was a little green plug ...ill go take another look at it
Old Jul 29, 2002
Black02's Avatar
Black02 is an unknown quantity at this point
Don't worry, its just a clip that goes on to the back of the baffle box, next to the air filter box. It does nothing except to hold a wire against the box. I wouldn't worry about it at all. Nothing bad will happen to your car.
Old Jul 30, 2002
y2k2ciVic's Avatar
y2k2ciVic is an unknown quantity at this point
thanks notorious, i was curious too, i didnt know we had an "airflow" sensor on the intake...
Old Jul 30, 2002
CapYoda's Avatar
Escaped Convict
its usually refer to as the MAS or air temp sensor or what not..
it sense the amount of air going into the throttle body.. and the air's temperature...
without it, what aftermarket intake claims wont work at all... as the ECU wont read the extra flow of air and adjust the fuel mixture accordingly...
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
danace99
23
Jun 28, 2015 08:49 AM
carid
Apr 30, 2015 07:00 AM
kanin247
Bolt-on Engine Performance
Apr 25, 2015 05:44 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
